Guten Tag,
wir bekomme fast täglich diesen SQL Fehler, nach ein Neustart des Servers kommt man wieder auf die Oberfläche des Shops.
Fatal error : Uncaught exception ‘PDOException’ with message ‘SQLSTATE[HY000]: General error: 1016 Can’t open file: ‘./shopware/s_core_plugins.frm’ (errno: 24 - Too many open files)’ in /var/www/vhosts/txxx/engine/Library/Zend/Db/Statement/Pdo.php:228 Stack trace: #0 /var/www/vhosts/triton949.startdedicated.de/livingforum.de/engine/Library/Zend/Db/Statement/Pdo.php(228): PDOStatement->execute(Array) #1 /var/www/vhosts/xx/engine/Library/Zend/Db/Statement.php(303): Zend_Db_Statement_Pdo->_execute(Array) #2 /var/www/xxxxx/engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend_Db_Statement->execute(Array) #3 /var/www/vhosts/xxxx/engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query(’? SE…’, Array) #4 /var/www/vhosts/xxxx/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(75): Zend in /var/www/vhosts/xxxx/engine/Library/Zend/Db/Statement/Pdo.php on line 234
503 Service Unavailable
