täglich 3 verschiedene Fehlermeldungen
Seit Einrichtung unseres Online-Shops im September 2013 habe ich täglich solchge Fehlermeldung bis zu 20 Stück. Was ist der Grund dafür kann mir da jemand weiterhelfen, wäre sehr dankbar dafür. Fehlermeldung 1 2014-01-02T16:04:57+01:00 ERR (3): exception ‘Exception’ with message ‘License check for module “SwagBusinessEssentials” has failed.’ in /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Community/Backend/SwagBusinessEssentials/Bootstrap.php:166 Stack trace: #0 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Community/Backend/SwagBusinessEssentials/Bootstrap.php(166): Shopware_Plugins_Backend_SwagBusinessEssentials_Bootstrap::checkLicense() #1 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Community/Backend/SwagBusinessEssentials/Bootstrap.php(455): Shopware_Plugins_Backend_SwagBusinessEssentials_Bootstrap->checkLicense() #2 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_SwagBusinessEssentials_Bootstrap->onGetControllerPathPrivateLogin(Object(Enlight_Event_EventArgs)) #3 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Event/EventManager.php(203): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Event_EventArgs)) #4 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(366): Enlight_Event_EventManager->notifyUntil(‘Enlight_Control…’, Array) #5 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(445): Enlight_Controller_Dispatcher_Default->getControllerPath(Object(Enlight_Controller_Request_RequestHttp)) #6 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(484): Enlight_Controller_Dispatcher_Default->isDispatchable(Object(Enlight_Controller_Request_RequestHttp)) #7 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #8 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/HttpKernel.php(79): Enlight_Controller_Front->dispatch() #9 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #10 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(242): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #11 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(403): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #12 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(303): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #13 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(162): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #14 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #15 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(97): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #16 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #17 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Application.php(192): Shopware_Bootstrap->run() #18 /homepages/6/d78355257/htdocs/shop/shopware.php(83): Enlight_Application->run() #19 {main} Fehlermeldung 2 2013-12-18T14:54:43+01:00 ERR (3): exception ‘Zend_Rest_Client_Result_Exception’ with message ‘REST Response Error: simplexml_load_string(): ^’ in /homepages/6/d78355257/htdocs/shop/engine/Library/Zend/Rest/Client/Result.php:61 Stack trace: #0 /homepages/6/d78355257/htdocs/shop/engine/Library/Zend/Rest/Client.php(265): Zend_Rest_Client_Result->__construct(‘Die Shopware Co…’) #1 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Default/Backend/StoreApi/StoreApi/Core/Rest/Client.php(67): Zend_Rest_Client->__call(‘post’, Array) #2 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Default/Backend/StoreApi/StoreApi/Core/Rest/Client.php(67): Zend_Rest_Client->post() #3 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Default/Backend/StoreApi/StoreApi/Core/Gateway/Gateway.php(48): Shopware_StoreApi_Core_Rest_Client->call(‘GET’, ‘auth/check’, Array) #4 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Default/Backend/StoreApi/StoreApi/Core/Gateway/Auth.php(44): Shopware_StoreApi_Core_Gateway_Gateway->get(‘auth/check’, Array) #5 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Default/Backend/StoreApi/StoreApi/Core/Service/Auth.php(49): Shopware_StoreApi_Core_Gateway_Auth->isTokenValid(NULL, NULL) #6 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Default/Core/PluginManager/Components/Store.php(167): Shopware_StoreApi_Core_Service_Auth->isTokenValid(Object(Shopware_StoreApi_Models_Auth)) #7 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Default/Core/PluginManager/Controllers/Backend/Store.php(59): CommunityStore->isLoggedIn() #8 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Action.php(148): Shopware_Controllers_Backend_Store->getLoginAction() #9 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‘getLoginAction’) #10 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #11 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/HttpKernel.php(79): Enlight_Controller_Front->dispatch() #12 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #13 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(242): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #14 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(230): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #15 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(86): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #16 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #17 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Application.php(192): Shopware_Bootstrap->run() #18 /homepages/6/d78355257/htdocs/shop/shopware.php(83): Enlight_Application->run() #19 {main} Fehlermeldung 3 2013-12-18T13:41:10+01:00 ERR (3): exception ‘SmartyException’ with message ‘Unable to load template snippet ‘frontend/private_register/index.tpl|b2bessentials/psblocks.tpl|frontend/plugins/seo/index.tpl|frontend/plugins/advanced_menu/index.tpl|frontend/plugins/google/index.tpl|frontend/plugins/diwShoplupeFeedback/index.tpl|index/header.tpl|frontend/plugins/ReihenLogo/index.tpl’’ in /homepages/6/d78355257/htdocs/shop/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127 Stack trace: #0 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/View/Default.php(273): Smarty_Internal_TemplateBase->fetch() #1 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default)) #2 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #3 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #4 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Event_EventArgs)) #5 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Event_EventArgs)) #6 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Event/EventManager.php(165): Enlight_Event_Handler_Default->execute(Object(Enlight_Event_EventArgs)) #7 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Action.php(191): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Array) #8 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‘indexAction’) #9 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #10 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/HttpKernel.php(79): Enlight_Controller_Front->dispatch() #11 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(242): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(230): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(245): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #16 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(188): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #17 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(97): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #19 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Application.php(192): Shopware_Bootstrap->run() #20 /homepages/6/d78355257/htdocs/shop/shopware.php(83): Enlight_Application->run() #21 {main}
So wie das aussieht, werden die Fehlermeldungen vom Business Essentials Plugin erzeugt. Da die erste gleich was von Lizenzprüfung spricht - existiert für das Plugin eine gültige Lizenz und wurde diese auch im Lizenzmanager hinterlegt?
Business Essentials wurde gekauft und es ist auch eine Lizenz hinterlegt im Lizenz-Manager
Schon mal versucht das Plugin neu zu installieren? Bzw ist das Plugin im der aktuellsten Version installiert?
Vielen Dank für den Hinweis, leider macht er immer noch diese Fehlermeldungen auch nach einer Neuinstallation.
Hi volimea, überprüfe hier noch einmal die eingetragene Lizenz sowie deinen Host Eintrag in den Grundeinstellungen. Hierbei ist es wichtig auf www zu achten. Wenn die Domain auf www.ihredomain.de lizenziert ist muss die Domain auch mit www.ihredomain.de im Host eingetragen werden. Gruß Dennis
Vielen Dank, die Fehlermeldungen sind BIS JETZT nicht wieder aufgetreten, dafür kommt einen neue Fehlermeldung. 2014-01-07T15:38:43+01:00 ERR (3): exception ‘Enlight_Controller_Exception’ with message ‘Unauthorized’ in /homepages/6/d78355257/htdocs/shop/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:213 Stack trace: #0 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Event_EventArgs)) #1 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Event/EventManager.php(165): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Event_EventArgs)) #2 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Action.php(128): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Array) #3 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‘getTurnOverVisi…’) #4 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #5 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/HttpKernel.php(79): Enlight_Controller_Front->dispatch() #6 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(242): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /homepages/6/d78355257/htdocs/shop/engine/Library/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(230): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(86): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /homepages/6/d78355257/htdocs/shop/engine/Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #11 /homepages/6/d78355257/htdocs/shop/engine/Library/Enlight/Application.php(192): Shopware_Bootstrap->run() #12 /homepages/6/d78355257/htdocs/shop/shopware.php(83): Enlight_Application->run() #13 {main}
Hallo, Leider sind die Fehlermeldungen wieder aufgetreten. nach einigen Tests ist mir aufgefallen das es meist bei der Reistrierung auftritt und zwar wenn man ein Pflichtfeld vergisst nicht einzutragen kommt dann nach “Registrierung abschließen” sofort die Fehlermeldung. KAnn mir jemand helfen???
[quote=„volimea“]Hallo, Leider sind die Fehlermeldungen wieder aufgetreten. nach einigen Tests ist mir aufgefallen das es meist bei der Reistrierung auftritt und zwar wenn man ein Pflichtfeld vergisst nicht einzutragen kommt dann nach „Registrierung abschließen“ sofort die Fehlermeldung. Kann mir jemand helfen???[/quote] Nochmal die fehlermeldung die auftritt Unable to load template snippet ‚frontend/private_register/index.tpl|b2bessentials/psblocks.tpl|frontend/plugins/seo/index.tpl|frontend/plugins/advanced_menu/index.tpl|frontend/plugins/google/index.tpl|index/header.tpl|frontend/plugins/ReihenLogo/index.tpl|frontend/index/bundle_header.tpl‘ in Smarty/sysplugins/smarty_internal_templatebase.php on line 127 Stack trace: #0 Enlight/View/Default.php(273): Smarty_Internal_TemplateBase->fetch() #1 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default)) #2 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #3 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #4 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Event_EventArgs)) #5 Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Event_EventArgs)) #6 Enlight/Event/EventManager.php(165): Enlight_Event_Handler_Default->execute(Object(Enlight_Event_EventArgs)) #7 Enlight/Controller/Action.php(191): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Array) #8 Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‚indexAction‘) #9 Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #10 Shopware/Components/HttpCache/HttpKernel.php(79): Enlight_Controller_Front->dispatch() #11 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 Shopware/Components/HttpCache/AppCache.php(242): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(230): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(245): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #16 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(188): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #17 Shopware/Components/HttpCache/AppCache.php(97): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #19 Enlight/Application.php(192): Shopware_Bootstrap->run() #20 shopware.php(83): Enlight_Application->run() #21 {main}
Hello, hab den gleichen Fehler. Wenn ich die Domain mit “https://” aufrufe geht es nicht. Mit “http://” funktioniert alles wunderbar. Ich melde mich nochmal falls ich ein Fix finde.
wir haben das gleiche Probelm mit den Business essentials. Wir bekommen auch die folgende Fehlermeldung: Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Unable to load template snippet 'frontend/private\_register/index.tpl|b2bessentials/psblocks.tpl|frontend/bepado/index/index.tpl|frontend/plugins/seo/index.tpl|frontend/plugins/swag\_hide\_prices/index.tpl' in Smarty/sysplugins/smarty\_internal\_templatebase.php on line 127 Stack trace: #0 Enlight/View/Default.php(273): Smarty\_Internal\_TemplateBase-\>fetch() #1 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default)) #2 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default)) #3 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render() #4 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs)) #5 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs)) #6 Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #7 Enlight/Controller/Action.php(202): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #8 Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('indexAction') #9 Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #10 Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #11 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(244): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 Shopware/Components/HttpCache/AppCache.php(132): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #16 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(190): Shopware\Components\HttpCache\AppCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #17 Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #19 {main} Die Business Esentials Lizenz ist korrekt hinterlegt. Auch der Host der lizenz stimmt mit der Domain des Shops bzw des subshops überein. Brauchen dringend hilf hierzu. Gruß Florian
