Guten Tag Ich habe einen Clone unseres Shops erstellt und den Update via Browser auf 5.0.0 versucht. Während dem Update erhalte ich im Browser folgende Meldung: Slim Application Error The application could not run because of the following error: Details Type: ErrorException Code: 2 Message: file_get_contents(/var/www/vhosts/domain/test.domain.ch/engine/Shopware/Plugins/Default/Backend/.svn/Bootstrap.php): failed to open stream: No such file or directory File: /var/www/vhosts/domain/test.domain.ch/recovery/update/src/DummyPluginFinder.php Line: 80 Trace #0 [internal function]: Slim\Slim::handleErrors(2, ‘file_get_conten…’, ‘/var/www/vhosts…’, 80, Array) #1 /var/www/vhosts/domain/test.domain.ch/recovery/update/src/DummyPluginFinder.php(80): file_get_contents(’/var/www/vhosts…’) #2 /var/www/vhosts/domain/test.domain.ch/recovery/update/src/DummyPluginFinder.php(57): Shopware\Recovery\Update\DummyPluginFinder->isDummyPlugin(’/var/www/vhosts…’) #3 /var/www/vhosts/domain/test.domain.ch/recovery/update/src/Controller/CleanupController.php(92): Shopware\Recovery\Update\DummyPluginFinder->getDummyPlugins() #4 /var/www/vhosts/domain/test.domain.ch/recovery/update/src/app.php(159): Shopware\Recovery\Update\Controller\CleanupController->cleanupOldFiles() #5 [internal function]: {closure}() #6 /var/www/vhosts/domain/test.domain.ch/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array) #7 /var/www/vhosts/domain/test.domain.ch/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch() #8 /var/www/vhosts/domain/test.domain.ch/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call() #9 /var/www/vhosts/domain/test.domain.ch/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call() #10 /var/www/vhosts/domain/test.domain.ch/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call() #11 /var/www/vhosts/domain/test.domain.ch/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call() #12 /var/www/vhosts/domain/test.domain.ch/recovery/update/index.php(46): Slim\Slim->run() #13 {main} Die Datei /var/www/vhosts/domain/test.domain.ch/engine/Shopware/Plugins/Default/Backend/.svn/Bootstrap.php gibt es aber weder im Original noch im Clone unseres Shops Wenn ich danach den Updateordner lösche, gelange ich in die 4.3.6 installation Grüsse Urs
Hallo Urs, da wird folgende Datei bemängelt: /var/www/vhosts/domain/test.domain.ch/engine/Shopware/Plugins/Default/Backend/.svn/Bootstrap.php So ein Ordner mit /.svn/ gehört nicht in die Installation und verursacht bei dir scheinbar die Probleme. Die sollten am besten entfernt werden Sebastian
Lösungen können soo einfach sein! Ordner gelöscht ->Funktioniert!
