Hallo, bekomme beim update diese Fehlermedlung und dann geht es nicht weiter. Update läuft normal mit DB Update und dann kommt mit der URL /recovery/update/index.php/cleanup das : Slim Application Error The application could not run because of the following error: Details Type: ErrorException Code: 2 Message: file_get_contents(/www/htdocs/sw/engine/Shopware/Plugins/Default/Frontend/SofortPayment/Bootstrap.php): failed to open stream: No such file or directory File: /www/htdocs/sw/recovery/update/src/DummyPluginFinder.php Line: 80 Trace #0 [internal function]: Slim\Slim::handleErrors(2, ‘file_get_conten…’, ‘/www/htdocs/sw…’, 80, Array) #1 /www/htdocs/sw/recovery/update/src/DummyPluginFinder.php(80): file_get_contents(’/www/htdocs/sw…’) #2 /www/htdocs/sw/recovery/update/src/DummyPluginFinder.php(57): Shopware\Recovery\Update\DummyPluginFinder->isDummyPlugin(’/www/htdocs/sw…’) #3 /www/htdocs/sw/recovery/update/src/Controller/CleanupController.php(92): Shopware\Recovery\Update\DummyPluginFinder->getDummyPlugins() #4 /www/htdocs/sw/recovery/update/src/app.php(159): Shopware\Recovery\Update\Controller\CleanupController->cleanupOldFiles() #5 [internal function]: {closure}() #6 /www/htdocs/sw/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array) #7 /www/htdocs/sw/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch() #8 /www/htdocs/sw/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call() #9 /www/htdocs/sw/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call() #10 /www/htdocs/sw/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call() #11 /www/htdocs/sw/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call() #12 /www/htdocs/sw/recovery/update/index.php(46): Slim\Slim->run() #13 {main} hab auf dem FTP geschaut im Ordner : www/htdocs/sw/engine/Shopware/Plugins/Default/Frontend/SofortPayment/ fehlt die Datei: Bootstrap.php Gruss
Er versucht an der Stelle aufzuräumen und sucht eine Bootstrap.php, die er nicht finden kann - zum Löschen. Erstelle dir ein Backup von /www/htdocs/sw/engine/Shopware/Plugins/Default/Frontend/SofortPayment/Bootstrap.php und dann lösche das Verzeichnis mal von Hand - dann sollte es klappen.
