ich habe durch FTP die ganzen Daten zur meinem Server hochgeladen, wollte mit der Installation starten danach bekomme ich die Fehlermeldung beim eingeben meiner Domain.
Kann jemand damit was Anfangen???
Vielen Dank auf jeden Fall im Voraus für eure Bemühungen.
Slim Application Error
Type: ErrorException
Code: 2
Message: file_put_contents(/is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/install/data/uniqueid.txt): failed to open stream: Permission denied
File: /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/src/Service/UniqueIdGenerator.php
Line: 85
Trace
#0 [internal function]: Slim\Slim::handleErrors(2, ‘file_put_conten…’, ‘/is/htdocs/wp11…’, 85, Array)#1 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/src/Service/UniqueIdGenerator.php(85): file_put_contents(’/is/htdocs/wp11…’, ‘053iEYzGObJqctk…’)#2 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/src/Service/UniqueIdGenerator.php(58): Shopware\Recovery\Common\Service\UniqueIdGenerator->saveUniqueId(‘053iEYzGObJqctk…’)#3 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/install/src/ContainerProvider.php(216): Shopware\Recovery\Common\Service\UniqueIdGenerator->getUniqueId()#4 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))#5 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/install/src/app.php(205): Pimple\Container->offsetGet(‘shopware.notify’)#6 [internal function]: {closure}()#7 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)#8 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()#9 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()#10 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()#11 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()#12 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()#13 /is/htdocs/wp11207486_VHL6HMS51R/www/shop/recovery/install/index.php(74): Slim\Slim->run()
#14 {main}
