Hallo ihr Lieben, ich bekomme hier diese fehler Meldung angezeigt:
http://sneaker-angebote.de/recovery/install/
Slim Application Error
Type: ErrorException
Code: 2
Message: file_put_contents(/var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/install/data/uniqueid.txt): failed to open stream: Permission denied
File: /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/src/Service/UniqueIdGenerator.php
Line: 85
Trace
#0 [internal function]: Slim\Slim::handleErrors(2, ‚file_put_conten…‘, ‚/var/www/vhosts…‘, 85, Array)#1 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/src/Service/UniqueIdGenerator.php(85): file_put_contents(’/var/www/vhosts…’, ‚lgNKnzyu6ONcBZA…‘)#2 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/src/Service/UniqueIdGenerator.php(58): Shopware\Recovery\Common\Service\UniqueIdGenerator->saveUniqueId(‚lgNKnzyu6ONcBZA…‘)#3 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/install/src/ContainerProvider.php(216): Shopware\Recovery\Common\Service\UniqueIdGenerator->getUniqueId()#4 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))#5 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/install/src/app.php(175): Pimple\Container->offsetGet(‚shopware.notify‘)#6 [internal function]: {closure}()#7 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)#8 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()#9 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()#10 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()#11 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()#12 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()#13 /var/www/vhosts/sneaker-angebote.de/httpdocs/recovery/install/index.php(75): Slim\Slim->run()
#14 {main}
Kann mir jemand helfen?
