Shopware 6 documentation
Some entries in the documentation have missing steps or errors
Per example: https://docs.shopware.com/en/shopware-platform-dev-en/how-to/custom-cms-element?category=shopware-platform-dev-en/how-to
It forgets to mention that you need to add
import './config';
into the main.js file
Otherwise is not going to work
Is there a way to point out these issues on the documentation?
You could fix them with a pull request: platform/300-custom-cms-element.md at a6797e03c6dd97674cdc93322fb499aed5f88ff8 · shopware/platform · GitHub
The documentation is part of our repository. Otherwhise you can create an issue for it (issues.shopware.com or github issue)
