Hi, i’m setting up a demo store and i’m trying to add some products with multiple options to choose from.
When creating variants with use of a property, you can only choose one property option at once. But i would like to have something like this:
https://www.supportdesk.shop/magento-in-beheer-name
Here you can select multiple options at once, the price would also stack up.
I have not found a way to replicate this in shopware (6). I tried a workaround, where i made a single property for every option with just ‘yes’ and ‘no’ property options. But this ofcourse is not the way it was meant to be used and it isn’t looking neat.
Besides this, a couple of issues, using the variant generator and filling in the price surcharge, when i give multiple properties a surcharge it only uses one. So if property 1 has a $200 surchage on the yes option and property 2 has a surchage of $800 on the yes option, it wil only work for option 2. Thus selecting yes on both properties results in only $800 instead of $1000.
One more thing, for every property i gave the yes option position 1 and the no option position 2, but it won’t show yes first for every property. Sometimes it is “Yes” then “No” and sometimes it is “No” then “Yes”.
