SELECT list is not in GROUP BY clause
Hi
When I am trying to execute these query in MySQL
SELECT
order_line_item.product_id,
order_line_item.label,
SUM(order_line_item.quantity) AS totalQuantity
FROM
order_line_item
GROUP BY
ORDER BY
totalQuantity
DESC
I got the following error
Error in query (1055): Expression #2 of SELECT list is not in GROUP BY clause and contains nonaggregated column ‘shopware6_demo.order_line_item.label’ which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by
SET GLOBAL sql_mode=(SELECT REPLACE(@@sql_mode,‚ONLY_FULL_GROUP_BY‘,’’));
you have to add „order_line_item.label“ to the group by list, then it should work.
P.S.: Maybe you could use th DAL for this kind of query.
Best Regards
Krispin
