HAllo!
Ich bekomme seit einigen Tagen immer wieder Error-Mails mit folgendem Inhalt:
ERROR
Message:
exception 'Enlight_Controller_Exception' with message 'Controller "ticket" not found for request url http://www.zawo-tec-shop.de/angebotsanfrage-zawo-tec-online-shop?sInquiry=detail&sOrdernumber=HD5008%27' in /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php:506
Stack trace:
#0 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#1 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#2 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#3 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#4 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#5 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(420): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#6 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#7 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#8 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#10 /var/www/vhosts/zawo-tec-shop.de/httpdocs/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#11 {main}
Time:
2018-11-04T09:54:41.746489+0100
Channel:
core
request:
    "uri": "/angebotsanfrage-zawo-tec-online-shop?sInquiry=detail&sOrdernumber=HD5008%27",
    "method": "GET",
    "query": {
        "sInquiry": "detail",
        "sOrdernumber": "HD5008'",
        "module": "frontend",
        "controller": "ticket",
        "action": "index",
        "sFid": "16",
        "rewriteAlias": "1"
    "post": []
session:
No session data available
shopId:
1
shopName:
ZaWo-Tec Shop
IN der Meldung wird ja „Angebotsanfrage“ erwähnt. Diese funktioniert aber einwandfrei. Kann mir jemand einen Tipp geben? Vielen Dank!
 Ticket hat aber bestimmt nichts mit “kommen keine Bestellungen mehr rein” zu tun.
