Versuche nun schon seit einer Weile das ScheduledTask Plugin ans Laufen zu bringen, bekomme aber einen „No handler for message „Swag\ScheduledTaskPlugin\ScheduledTask\MyTask“.“ Fehler, sobald das Plugin aktiviert und der ScheduledTask ausgeführt wird.
Folgende Schritte wurden ausgeführt:
Plugin gecloned
git clone https://github.com/shopware/swag-docs-scheduled-task-plugin.git custom/plugins/swag-docs-scheduled-task-plugin/
Plugin-Liste refreshed
bin/console plugin:refresh
Plugin im Backend installiert
Den Admin-Worker deaktiviert
/config/packages/shopware.yaml
shopware:
admin_worker:
enable_admin_worker: false -
Den Cache geleert
bin/console cache:clear
Den Task-Runner gestartet
bin/console scheduled-task:run -vvv
Den Message-Consumer gestartet
bin/console messenger:consume -vvv
Das Plugin im Backend aktiviert
Anschließend erscheint folgende Fehlermeldung im Message-Consumer:
15:45:59 INFO [messenger] Received message Swag\ScheduledTaskPlugin\ScheduledTask\MyTask
"message" => Swag\ScheduledTaskPlugin\ScheduledTask\MyTask^ {
#taskId: "c66f186b33ac4fa99c9c5a179c51405c"
"class" => "Swag\ScheduledTaskPlugin\ScheduledTask\MyTask"
15:45:59 ERROR [messenger] Error thrown while handling message Swag\ScheduledTaskPlugin\ScheduledTask\MyTask. Sending for retry #1 using 1000 ms delay. Error: "No handler for message "Swag\ScheduledTaskPlugin\ScheduledTask\MyTask"."
"class" => "Swag\ScheduledTaskPlugin\ScheduledTask\MyTask",
"retryCount" => 1,
"delay" => 1000,
"error" => "No handler for message "Swag\ScheduledTaskPlugin\ScheduledTask\MyTask".",
"exception" => Symfony\Component\Messenger\Exception\NoHandlerForMessageException^ {
#message: "No handler for message "Swag\ScheduledTaskPlugin\ScheduledTask\MyTask"."
#code: 0
#file: "./vendor/symfony/messenger/Middleware/HandleMessageMiddleware.php"
#line: 73
trace: {
./vendor/symfony/messenger/Middleware/HandleMessageMiddleware.php:73 { …}
./vendor/symfony/messenger/Middleware/SendMessageMiddleware.php:79 { …}
./vendor/shopware/core/Framework/MessageQueue/Middleware/RetryMiddleware.php:40 { …}
./vendor/symfony/messenger/Middleware/FailedMessageProcessingMiddleware.php:34 { …}
./vendor/symfony/messenger/Middleware/DispatchAfterCurrentBusMiddleware.php:67 { …}
./vendor/symfony/messenger/Middleware/RejectRedeliveredMessageMiddleware.php:42 { …}
./vendor/symfony/messenger/Middleware/AddBusNameStampMiddleware.php:37 { …}
./vendor/symfony/messenger/Middleware/TraceableMiddleware.php:43 { …}
./vendor/symfony/messenger/MessageBus.php:80 { …}
./vendor/shopware/core/Framework/MessageQueue/MonitoringBusDecorator.php:46 { …}
./vendor/symfony/messenger/TraceableMessageBus.php:41 { …}
./vendor/symfony/messenger/RoutableMessageBus.php:54 { …}
./vendor/symfony/messenger/Worker.php:117 { …}
./vendor/symfony/messenger/Worker.php:81 { …}
./vendor/symfony/messenger/Command/ConsumeMessagesCommand.php:202 { …}
./vendor/symfony/console/Command/Command.php:255 { …}
./vendor/symfony/console/Application.php:1027 { …}
./vendor/symfony/framework-bundle/Console/Application.php:97 { …}
./vendor/symfony/console/Application.php:273 { …}
./vendor/symfony/framework-bundle/Console/Application.php:83 { …}
./vendor/symfony/console/Application.php:149 { …}
./bin/console:68 {
› $application = new Application($kernel->getKernel());
› $application->run($input);
Vermutlich sitze ich schon zu lange dran und übersehe irgendwas essentielles. Aber was?
PS: die Tabelle „dead-message“ in der Datenbank ist leer.
PPS: es handelt sich um eine dockware Umgebung mit Shopware in der Version 6.3.3.0
