Hallo, wir haben in den error logs immer wieder einen Fehler:
2018/04/16 20:15:27 [error] 1706#1706: *2407579 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Error: Call to a member function renderEsiTag() on null in /var/www/clients/client1/web2/web/var/cache/production_201801171346/templates/frontend_XYZ_de_DE_1_secure/ee/ff/ee/eeffee45a61ee3beff8269d2772ca835e0202058.snippet.info.tpl.php:178
Stack trace:
#0 /var/www/clients/client1/web2/web/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(180): content_5ad45af4edf901_15783388(Object(Enlight_Template_Default))
#1 /var/www/clients/client1/web2/web/engine/Library/Enlight/View/Default.php(276): Smarty_Internal_TemplateBase->fetch()
#2 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#3 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#4 /var/www/clients/client1/web2/web/engine/" while reading response header from upstream, client: 92.72.224.209, server: domain.de, request: "GET /PaymentPaypal/return/express/1?token=EC-xxxxxxxxxxxxxxxx&PayerID=xxxxxxxxxxxxx HTTP/1.1", upstream: "fastcgi://unix:/var/lib/php5-fpm/web2.sock:", host: "www.domain.de", referrer: "https://www.paypal.com/webapps/hermes?flow=1-P&ulReturn=true&country.x=DE&hermesLoginRedirect=xoon&locale.x=de_DE&token=EC-xxxxxxxxxxxxxxxx&country.x=DE&locale.x=de_DE"
in der eeffee45a61ee3beff8269d2772ca835e0202058.snippet.info.tpl.php:178 steht folgendes:
<?php echo $_smarty_tpl->smarty-\>registered\_plugins[Smarty::PLUGIN\_FUNCTION]['action'][0][0]-\>renderEsiTag(array('module'=\>'widgets','controller'=\>'compare'),$\_smarty\_tpl);?\> der ganze Bereich sieht dann wie folgt aus: <?php ob_start();?><?php echo 1;?><?php $_tmp5=ob_get_clean();?><?php if ($_tmp5){?>
<?php echo _smarty_tpl->smarty-\>registered\_plugins[Smarty::PLUGIN\_FUNCTION]['action'][0][0]-\>renderEsiTag(array('module'=\>'widgets','controller'=\>'compare'),_smarty_tpl);?>
<?php }?>
Woran könnte das liegen? Wo müssen wir schauen um den Fehler zu finden?
Besten Dank!
