Rechnung erstellen ERROR // Umzug Anbieter
ich bekomme nach dem Umzug zu einem anderen Anbieter folgenden Fehler bei der Rechnungserstellung:
Could not resolve type of column "id" of class "Shopware\Models\Order\Document\Document" in vendor/doctrine/orm/lib/Doctrine/ORM/Utility/PersisterHelper.php on line 130
Stack trace:
#0 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(1357): Doctrine\ORM\Utility\PersisterHelper::getTypeOfColumn('id', Object(Doctrine\ORM\Mapping\ClassMetadata), Object(Shopware\Components\Model\ModelManager))
#1 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(1270): Doctrine\ORM\Persisters\Entity\BasicEntityPersister->getSelectColumnAssociationSQL('document', Array, Object(Doctrine\ORM\Mapping\ClassMetadata), 'e0')
#2 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(1100): Doctrine\ORM\Persisters\Entity\BasicEntityPersister->getSelectColumnsSQL()
#3 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(912): Doctrine\ORM\Persisters\Entity\BasicEntityPersister->getSelectSQL(Array, NULL, NULL, NULL, NULL, NULL)
#4 vendor/doctrine/orm/lib/Doctrine/ORM/EntityRepository.php(181): Doctrine\ORM\Persisters\Entity\BasicEntityPersister->loadAll(Array, NULL, NULL, NULL)
#5 engine/Shopware/Controllers/Backend/Order.php(946): Doctrine\ORM\EntityRepository->findBy(Array)
#6 engine/Library/Enlight/Controller/Action.php(193): Shopware_Controllers_Backend_Order->openPdfAction()
#7 engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight_Controller_Action->dispatch('openPdfAction')
#8 engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 engine/Shopware/Kernel.php(215): Enlight_Controller_Front->dispatch()
#10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(253): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#13 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#14 shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#15 {main}
Es wird die neuste Version 5.5.1 verwendet. Auf der restlichen Webseite wurde aber kein Fehler wegen dem Umzug gefunden.
Ich hoffe ihr könnt mir helfen.
habe nun zu meinem Problem die Lösung gefunden.
Vielleicht kann hiermit geholfen werden.
