Hello everyone,
I have a subscriber for the Shopware_Modules_Basket_UpdateArticle_Start event .
Background: I would like to check the graduated prices every time the shopping cart is updated - these come from an external REST API.
The event provides 2 parameters, ID and quantity. The ID belongs to the respective shopping cart item, how do I read it out now (item, quantity, price, etc.)?
There is the sBasket :: sGetBasket () function, but how do I get there from my plugin?
I also looked at the two services shopware.cart.basket_helper and shopware.cart.basket_query_helper , none of which return the shopping cart (by position).
Shopware () -> Modules () -> Basket () -> sGetBasket () leads to an error in the event discussed, presumably because it triggers the event itself.
How do you get here?
*Verdächtige Links entfernt*
Thank you,.
