Hi habe den update manuell gemacht da es mit dem plugin nicht funktuniert hatte habe jetzt folgendes problem wenn ich den domain aufrufe bekome ich diese meldung [quote] exception ‘SmartyException’ with message ‘Unable to parse resource name “”’ in /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Vendor/Smarty/libs/sysplugins/smarty_internal_template.php:103 Stack trace: #0 /var/www/vhosts/minalo.de/httpdocs/cache/templates/templates_orange_de_DE_1^79079726aeb6498d7be1b46d8ed63ab9c159c1c2.extends.index.tpl.php(743): Smarty_Internal_Template->__construct(NULL, Object(Enlight_Template_TemplateManager), Object(Enlight_Template_Template), NULL, NULL, NULL, NULL) #1 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(436): include(’/var/www/vhosts…’) #2 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Template/Template.php(46): Smarty_Internal_Template->renderTemplate() #3 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(568): Enlight_Template_Template->renderTemplate() #4 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Vendor/Smarty/libs/Smarty.class.php(328): Smarty_Internal_Template->getRenderedTemplate() #5 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(865): Smarty->fetch(Object(Enlight_Template_Template)) #6 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/View/ViewDefault.php(153): Smarty_Internal_Template->fetch() #7 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(87): Enlight_View_ViewDefault->render(Object(Enlight_Template_Template)) #8 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(102): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Template)) #9 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(43): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #10 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Event_EventArgs)) #11 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Event/EventHandler.php(60): call_user_func(Array, Object(Enlight_Event_EventArgs)) #12 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Event/EventManager.php(70): Enlight_Event_EventHandler->execute(Object(Enlight_Event_EventArgs)) #13 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Controller/Action.php(76): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Array) #14 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‘indexAction’) #15 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Controller/Front.php(99): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #16 /var/www/vhosts/minalo.de/httpdocs/engine/Shopware/Bootstrap.php(33): Enlight_Controller_Front->dispatch() #17 /var/www/vhosts/minalo.de/httpdocs/engine/Enlight/Enlight/Application.php(86): Shopware_Bootstrap->run() #18 /var/www/vhosts/minalo.de/httpdocs/shopware.php(6): Enlight_Application->run() #19 {main}[/quote] ins backend komme ich rein habe auch alle chash ordner gelöscht auch manuell was muss ich machen ? vielen dank voraus
hi ja das problem war der plugin für update hat nicht funktuniert deswegen hab ich es manuell gemacht und dabei habe ich die datei mit den images gesehen und habe es gelöscht weil der meine vorhandene bilder überschreiben tut und aus der not heraus habe ich den update erneu ohne etwas weg zu machen eingespielt hat dann funktuniert. allerding waren meine bilder sowie logo und template weg. lg manuel
