Problems with migration plugin
problems with migration plugin
Hello, my name is Enmanuel.
Add-on for shopware 5 to 6 migration plugin.
I have problems to use the shopware 5 to 6 migration plugin which presents a connection error.
Thank you very much in advance, I look forward to your answer.
attached image with communication e
rror when trying from shopware 6 to make the communication.
Hi Emmanuel,
maybe it will perform better, if you started the migration via command line. The commands are explained here: https://docs.shopware.com/en/migration-en/shopware6-Migrationsprocess#migration-of-large-amounts-of-data-by-the-console.
Kind regards,
Markus
i type the commands as it says in the documentation and i get this error, is it the same for shopware 5 and 6 ? i am running these commands in shopware 5
Hi Emmanuel,
the migration command must be started in your Shopware 6 command line. It is available there, if the migration plugin was installed there.
Kind regards,
Markus
