Probleme beim Login
Hi, ich komme nicht ins Backend.
Was besagt der Fehler`?
The provided CSRF-Token is invalid. If you’re sure that the request to path “/backend/Login?file=app&no-cache=1566398777” should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in engine/Shopware/Components/CSRFTokenValidator.php on line 106
Stack trace:
#0 engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator-\>checkBackendTokenValidation(Object(Enlight\_Controller\_ActionEventArgs))
 #1 engine/Library/Enlight/Event/EventManager.php(219): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #2 engine/Library/Enlight/Controller/Action.php(175): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #3 engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight\_Controller\_Action-\>dispatch('indexAction')
 #4 engine/Library/Enlight/Controller/Front.php(222): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #5 engine/Shopware/Kernel.php(202): Enlight\_Controller\_Front-\>dispatch()
 #6 vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #7 vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #8 engine/Shopware/Components/HttpCache/AppCache.php(260): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #9 vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #10 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #11 shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #12 {main}
probier es mal ohne “/Login?file=app&no-cache=1566398777”, routet er dich wieder darauf zurück oder kommst du dann auf die normale Backend-Seite?
Eigentlich steht bei der Anmeldung im Backend kein “/Login” dahinter.
