Probleme bei erstem Aufruf nach Installation
Hallo, habe shopware per Hand installiert und beim ersten Start passiert dann folgendes : Warning: call_user_func(Shopware_Proxies_ShopwareBootstrapProxy::getHookMethods) [function.call-user-func]: Unable to call Shopware_Proxies_ShopwareBootstrapProxy::getHookMethods() in /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Enlight/Hook/ProxyFactory.php on line 33 Warning: array_diff() [function.array-diff]: Argument #2 is not an array in /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Enlight/Hook/ProxyFactory.php on line 34 Warning: call_user_func(Shopware_Proxies_EnlightControllerFrontProxy::getHookMethods) [function.call-user-func]: Unable to call Shopware_Proxies_EnlightControllerFrontProxy::getHookMethods() in /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Enlight/Hook/ProxyFactory.php on line 33 Warning: array_diff() [function.array-diff]: Argument #2 is not an array in /var/www /vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Enlight/Hook/ProxyFactory.php on line 34 Fatal error: Uncaught exception ‚Zend_Controller_Response_Exception‘ with message ‚Cannot send headers; headers already sent in /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Enlight/Hook/ProxyFactory.php, line 33‘ in /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Vendor/Zend/library/Zend/Controller/Response/Abstract.php:321 Stack trace: #0 /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Vendor/Zend/library/Zend/Controller/Response/Abstract.php(115): Zend_Controller_Response_Abstract->canSendHeaders(true) #1 /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Shopware/Bootstrap.php(192): Zend_Controller_Response_Abstract->setHeader(‚Content-Type‘, ‚text/html; char…‘) #2 /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Enlight/Bootstrap.php(99): Shopware_Bootstrap->initFront() #3 /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Enlight/Bootstrap.php(69): Enlight_Bootstrap->loadResource(Array) #4 /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Shopware/Bootstrap.php(8): En in /var/www/vhosts/shop.ip-matrix.de/httpdocs/engine/Enlight/Vendor/Zend/library/Zend/Controller/Response/Abstract.php on line 321 was könnte das sein?
Kann es sein, dass dre Ordner engine/Shopware/Proxies keine Schreibrechte hat?
Hallo, nein das sieht gut aus: drwxrwxrwx 2 root root 4096 2011-02-02 17:44 Proxies
Hallo ! Kenne jetzt deine Serverkonfiguration nicht, aber Besitzer/Gruppe root root scheint mir falsch zu sein. Normal sollte root ja wirklich nur im root Bereich sein und nicht im Ordner htdocs oder www. Müsste eher user usergroup lauten !!! Root wäre im verzeichnis www/htdocs ja eigentlich eine Zugriffsperre ! lg klaus
Hallo, habe ich gerade mal geändert auf den Webuser, ändert aber an dem Fehler nichts - leider…
