Problem: Paypal Zahlung abschließen
Ich habe folgendes Problem - jedes mal, wenn man mit Paypal zahlen möchte, gelangt man problemlos richtung Paypal. Klickt man dort dann jedoch auf Zahlung abschließen, wird man zu folgender URL zurückgeleitet: (ich habe die sensiblen daten mal durch xxx bereinigt)
xxxxx.de/payment/finalize-transaction?_sw_payment_token=xxxxxxxx.xxxxxxxx
Unter dieser URL erhält man dann eine White-Page mit folgender Fehlermeldung:
	"errors":
			"status":
			"410",
			"code":
			"CHECKOUT__PAYMENT_TOKEN_EXPIRED",
			"title":
			"Gone",
			"detail":
			"The provided token xxxxxxxxxxxxxxxxxxxx
			is expired and the payment could not be processed.
			"meta":
				"parameters":
					"token":
					"xxxxxxxxxxxxxxxxxxxx"
swag_paypal_prod.log sagt folgendes
swag_paypal.ERROR:
 Swag\PayPal\RestApi\Client\AbstractClient:
 :handleRequestException (114): Client error: `PATCH https: //api.paypal.com/v1/notifications/webhooks/xxxxxxxxxxxxx` resulted in a `400 Bad Request` response:
 {"name": "WEBHOOK_PATCH_REQUEST_NO_CHANGE",
 "message":"No change in webhook",
 "debug_id":"ea5f1fbb2ea43",
 "information_link" (truncated...)  No change in webhook  [{"name":"WEBHOOK_PATCH_REQUEST_NO_CHANGE",
 "information_link":"https://developer.paypal.com/docs/api/webhooks/#errors",
 "details":[]
"links":[]
{"headers":{"content-type":"application/json"}
"json":[{"Swag\\PayPal\\RestApi\\V1\\Api\\Patch":{"op":"replace",
"path":"/url",
"value":"https://xxxx/api/_action/paypal/webhook/execute?sw-token=xxxxxxxxxxxxxxxxxxx"}
 {"file":"/var/www/share/xxxxxxxxx-shop/htdocs/custom/plugins/SwagPayPal/src/RestApi/Client/AbstractClient.php"}
swag_paypal.ERROR:
Swag\PayPal\Webhook\Registration\WebhookSystemConfigHelper:
checkWebhookAfter (115):
The error "WEBHOOK_PATCH_REQUEST_NO_CHANGE" occurred with the following message:
No change in webhook  {"error": "[object]
(Swag\\PayPal\\RestApi\\Exception\\PayPalApiException(code:
0):
The error \"WEBHOOK_PATCH_REQUEST_NO_CHANGE\" occurred with the following message:
No change in webhook  at /var/www/share/xxxxxxxxx-shop/htdocs/custom/plugins/SwagPayPal/src/RestApi/Client/AbstractClient.php:
116)"}
{"file":"/var/www/share/xxxxxxxxx-shop/htdocs/custom/plugins/SwagPayPal/src/Webhook/Registration/WebhookSystemConfigHelper.php"}
swag_paypal.ERROR:
 Client error:
 `GET https: //api.paypal.com/v1/notifications/webhooks/xxxxxxxxxxxxx` resulted in a `404 Not Found` response:  {
	"name":
	"INVALID_RESOURCE_ID",
	"message":
	"Resource id is invalid",
	"debug_id":
	"a02c617342931",
	"information_link":
	"https:// (truncated...)  Resource id is invalid  [
		"name":
		"message":
		"debug_id":
		"a02c617342931",
		"information_link":
		"details":[],
		"links":[]
	{"headers":[]}
Ich habe jetzt schon 3 mal bei Paypal die API Credentials in den Developereinstellungen gelöscht und durch Shopware („Einstellungen>Erweiterungen>Paypal>API Holen“) neu initialisiert. Zwischendurch auch schon den Frontend-Cache geleert → ohne Erfolg.
Was mache ich falsch? :fearful:
Hallo, ich habe das gleiche Problem. Gibt es eine Lösung dazu?
Ist evtl. PayPal PLUS aktiviert aber gar nicht beantragt?
Wir haben die Lösung gefunden:
Seit einem der letzten Updates wurde eine Minutenangabe für die Warenkorb-Session bei Shopware hinzugefügt. Diese sollte eigentlich initial auf 30 Minuten stehen. Bei uns stand sie auf 0 Minuten.
Im Admin Bereich in den Warenkorb-Einstellungen einfach die Zeit hochsetzen, danach ist der Fehler behoben.
Vielen vielen DANK!!!
