Hi, I have several plugins installed and activated, however they are not shown in the list of plugins. Why had they suddenly disappeared?
There is also such an error when I open the plugin page
I have already found the solution, if you upload a plugin and unzip it there from a macOS, then you need to remove the zip file and the MAC_OS folder which macOS creates by default.
