Some Plugins are deactivated from store without any information. It is very frustrating that there is neither proper explanation nor any contact information of the manufacturer.
Does anybody find it annoying to invest time to test a plugin only to find out at the end that the plugin is deactivated before you can actually buy it? Shopware should at least provide other options of buying the plugin or the contact information of the plugin manufacturer.
