Bei unserer Testumgebung taucht nach dem Update dieser Fehler auf:
Slim Application Error
Type: Symfony\Component\DependencyInjection\Exception\InvalidArgumentException
Message: Class "Xervice\DataProvider\Communication\Console\CleanCommand" used for service "Xervice\DataProvider\Communication\Console\CleanCommand" cannot be found.
File: /www/htdocs/w0196654/gettest.de/BigBoxx/vendor/symfony/console/DependencyInjection/AddConsoleCommandPass.php
Line: 56
Trace
#0 /www/htdocs/w0196654/gettest.de/BigBoxx/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\Console\DependencyInjection\AddConsoleCommandPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#1 /www/htdocs/w0196654/gettest.de/BigBoxx/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#2 /www/htdocs/w0196654/gettest.de/BigBoxx/engine/Shopware/Kernel.php(552): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#3 /www/htdocs/w0196654/gettest.de/BigBoxx/engine/Shopware/Kernel.php(240): Shopware\Kernel->initializeContainer()
#4 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/update/src/DependencyInjection/Container.php(177): Shopware\Kernel->boot()
#5 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection\{closure}(Object(Pimple\Container))
#6 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/update/src/DependencyInjection/Container.php(186): Pimple\Container->offsetGet('shopware.contai...')
#7 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection\{closure}(Object(Pimple\Container))
#8 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/src/DependencyInjection/Container.php(71): Pimple\Container->offsetGet('shopware.theme_...')
#9 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/update/src/app.php(169): Shopware\Recovery\Common\DependencyInjection\Container->get('shopware.theme_...')
#10 [internal function]: {closure}()
#11 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#12 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#13 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#14 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#15 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#16 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#17 /www/htdocs/w0196654/gettest.de/BigBoxx/recovery/update/index.php(57): Slim\Slim->run()
#18 {main}
Kann uns jemand helfen?
Beste Grüße
Pasi
