Nach PHP Sicherheitsupdate auf 8.3.13 kommt im Frontend nur noch 500
Guten Morgen,
falls bei jemandem im Frontend nur noch ein 500 kommt,
könnte das an dem PHP Sicherheitsupdate (Release vor ca. 6 Tagen) liegen auf die Versionen 8.2.25 und 8.3.13, wenn zur gleichen Zeit Redis aktiv ist.
Bei uns installierte Shopware Version ist 6.6.6.1
Workaround ist REDIS zu deaktivieren.
Hat jemand die 6.6.7.1 am Laufen mit der neuesten PHP Version und REDIS?
Viele Grüße,
Matthias Rau
Hatten wir auch. Muss beim Hoster gelöst werden. Liegt an Inkompatibiltät von Redis zu bestimmten PHP Versionen. Also es liegt nicht in der Shopware-Version.
Der Text vom Hoster (TimmeHosting):
Thank you for your message and for your feedback regarding the redis.so extension.
As your hosting partner, we ensure that our servers are always equipped with the latest PHP versions and related modules to provide optimal security, stability, and performance. To maintain this standard, we update PHP versions and associated modules promptly, as new versions often include critical bug fixes and security improvements. Each update undergoes rigorous testing in a comprehensive test environment to confirm reliability and functionality before being deployed on our servers.
With the recent update to PHP 8.2.25 and 8.3.13, we also upgraded the Redis module for PHP to version 6.1.0. Unfortunately, this update led to an unexpected incompatibility with some Symfony-based applications, such as Shopware, that use Redis. To restore full functionality for these applications as quickly as possible, we have temporarily reverted the Redis module to the previous version 6.0.2.
This downgrade is intended as a temporary solution, as newer versions like 6.1.0 bring substantial improvements in security, performance, and stability that we aim to offer you in the long term. However, since Symfony is currently not fully compatible with Redis module 6.1.0, we are unable to provide the full benefits of this version at this time. We are hopeful that Symfony will soon release an update to resolve this incompatibility, allowing you and your clients to take advantage of the latest technologies.
We are also reviewing our testing processes to identify potential issues like this sooner, ensuring a seamless update of all components. Your satisfaction is our top priority, and we thank you for your understanding and trust. For any further questions or additional information, please do not hesitate to reach out to our support team.
es sieht so aus, als ob das Problem mit dem 500-Fehler im Frontend tatsächlich auf ein PHP-Sicherheitsupdate in Verbindung mit Redis zurückzuführen ist. Solche Schwierigkeiten können auftreten, wenn die verwendeten Versionen nicht vollständig kompatibel sind. Das ist ähnlich wie bei https://mostbetde.de/tenis/, hat aber natürlich seine eigenen Eigenheiten. Ich habe von anderen Leuten gehört, dass sie ähnliche Probleme mit Shopware 6.6.6.6.1 und Redis hatten, nachdem sie auf die neuesten PHP-Versionen aktualisiert hatten.
entspricht unserer Erfahrung.
