Module not found: Error: Can't resolve '@vue/test-utils_v3' -> ./bin/build-administration.sh -> Shopware 6.6.5.1
habe leider ein Problem beim Backend compile „./bin/build-administration.sh“.
Ich hatte erstmal auf die Version 6.6.5.1 aktualisiert.
Beim Plugin fixen konnte das backend aber nicht mehr sauber erzeugt werden.
Ich habe alle Plugins deaktiviert, bekomme vom core aber die folgende Fehlerinfo:
[webpack-cli] ModuleNotFoundError: Module not found: Error: Can't resolve '@vue/test-utils_v3' in 'MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/src/app/plugin'
    at MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/lib/Compilation.js:2022:28
    at MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/lib/NormalModuleFactory.js:817:13
    at eval (eval at create (MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/node_modules/tapable/lib/HookCodeFactory.js:33:10), <anonymous>:10:1)
    at MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/lib/NormalModuleFactory.js:275:22
    at eval (eval at create (MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/node_modules/tapable/lib/HookCodeFactory.js:33:10), <anonymous>:9:1)
    at MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/lib/NormalModuleFactory.js:448:22
    at MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/lib/NormalModuleFactory.js:118:11
    at MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/lib/NormalModuleFactory.js:689:25
    at MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/lib/NormalModuleFactory.js:893:8
    at MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/webpack/lib/NormalModuleFactory.js:1013:5
  Parsed request is a module
  using description file: MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/package.json (relative path: ./src/app/plugin)
    Field 'browser' doesn't contain a valid alias configuration
    resolve as module
      MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/src/app/plugin/node_modules doesn't exist or is not a directory
      MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/src/app/node_modules doesn't exist or is not a directory
      MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/src/node_modules doesn't exist or is not a directory
      looking for modules in MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules
        single file module
          using description file: MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/package.json (relative path: ./node_modules/@vue/test-utils_v3)
            no extension
              MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/@vue/test-utils_v3 doesn't exist
            .js
              MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/@vue/test-utils_v3.js doesn't exist
            .ts
              MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/@vue/test-utils_v3.ts doesn't exist
            .vue
              MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/@vue/test-utils_v3.vue doesn't exist
            .json
              MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/@vue/test-utils_v3.json doesn't exist
            .less
              MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/@vue/test-utils_v3.less doesn't exist
            .twig
              MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/node_modules/@vue/test-utils_v3.twig doesn't exist
      MYPROJECTPATH/vendor/shopware/administration/Resources/app/node_modules doesn't exist or is not a directory
      MYPROJECTPATH/vendor/shopware/administration/Resources/node_modules doesn't exist or is not a directory
      MYPROJECTPATH/vendor/shopware/administration/node_modules doesn't exist or is not a directory
      MYPROJECTPATH/vendor/shopware/node_modules doesn't exist or is not a directory
      MYPROJECTPATH/vendor/node_modules doesn't exist or is not a directory
      MYPROJECTPATH/node_modules doesn't exist or is not a directory
      /var/www/html/shopware/luls6/node_modules doesn't exist or is not a directory
      /var/www/html/shopware/node_modules doesn't exist or is not a directory
      /var/www/html/node_modules doesn't exist or is not a directory
      /var/www/node_modules doesn't exist or is not a directory
      /var/node_modules doesn't exist or is not a directory
ich hab npm install mal im „MYPROJECTPATH/vendor/shopware/administration/Resources/app/administration/src/app/plugin“ ausgeführt. Hier hat er aber nichts weiter installiert.
Meine eigenen Plugins konnte er offenbar erstellen. Weil er beim Core aber dieses Problem hat, hab ich mal alles anderen deaktiviert.
Einen Ordner „node_modules/@vue/test-utils_v3“ gibts halt leider nicht. Nur ein node_modules/@vue/test-utils
Installiert sind
node v20.13.1
npm 10.5.2
die package.json im administration folder sagt
„engines“: {
„node“: „^20.0.0“,
„npm“: „>=10.0.0“
sollte daher passen eigentlich.
Hat einer da ne idee oder hat nen ordner „test-utils_v3“ zufällig rumliegen.?`
Grüße Marko
Ok, das Problem war das offenbar beim update im vendor ordner nicht alles sauber gezogen wurde.
Nachdem ich kompletten vendor ordner gelöscht und nochmal einen install hab drüber laufen lassen, geht es jetzt einfach.
Nur mal wieder ein random fehler, der einem vom arbeiten abhält. :tired_face:
