Migrationstool WooCommerce
Hallo!
Beim Migrieren von Shopdaten aus meinem alten WooCommerce erhalte ich immer den Fehler:
The server aborted the import without any error message. Usually this is caused by low max-execution limits or SQL-server timeouts.What can you do about this?* Check your max-execution timeout* Check your mysql server configuration* Add additional indizes to your source database in order to speed up the queries. Please refer to our documentation regarding the last option.
Ich habe folgendes in der fpm-php.log gefunden:
[23-Oct-2018 12:10:18 Europe/Berlin] PHP Fatal error: Allowed memory size of 5368709120 bytes exhausted (tried to allocate 4096 bytes) in example/www/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php on line 105
Jemand eine Idee, wie ich diesen Fehler beseitigen kann?
