Memory Limit CronJob
Grüße ich bekomme immer eine Memory Limit Fehler angezeigt.
Folgende Einstellungen wurden vorgenommen.
Cronjob alle 5 Minuten
#!/bin/bash
php /home/www/p579281/html/shopware/bin/console messenger:consume default --time-limit=360 --memory-limit=512M
php /home/www/p579281/html/shopware/bin/console scheduled-task:run --time-limit=60
php.ini
memory_limit = 1024M (Wurde von unserem Webhorst so eingestellt)
post_max_size = 512M
upload_max_filesize = 512M
Das hat dann genau 1x funktioniert.
[OK] Consuming messages from transports „default“.
// The worker will automatically exit once it has exceeded 1020 of memory, been
// running for 360s or received a stop signal via the messenger:stop-workers
// command.
// Quit the worker with CONTROL-C.
13:35:02 INFO [messenger] Received message Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask [„message“ => Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask { …},„class“ => „Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask“]
13:35:03 INFO [app] cache-miss: context-factory-696edab409aa400e9f76e95471bdc8ed
13:35:03 INFO [messenger] Message Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask handled by Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTaskHandler::__invoke [„message“ => Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask { …},„class“ => „Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask“,„handler“ => „Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTaskHandler::__invoke“]
13:35:03 INFO [messenger] Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask was handled successfully (acknowledging to transport). [„message“ => Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask { …},„class“ => „Shopware\Core\Content\ProductExport\ScheduledTask\ProductExportGenerateTask“]
13:35:03 INFO [messenger] Worker stopped due to memory limit of 1020 bytes exceeded (48758784 bytes used) [„limit“ => 1020,„memory“ => 48758784]
Jetzt gibt es alle 5 Minuten die Meldung
// The worker will automatically exit once it has exceeded 512M of memory, been
// command.
// Re-run the command with a -vv option to see logs about consumed messages.
07:10:19 CRITICAL [php] Fatal Error: Allowed memory size of 1073741824 bytes exhausted (tried to allocate 479232 bytes) [„exception“ => Symfony\Component\ErrorHandler\Error\OutOfMemoryError { …}]
In PDOStatement.php line 262:
479232 bytes)
messenger:consume [-l|–limit LIMIT] [-f|–failure-limit FAILURE-LIMIT] [-m|–memory-limit MEMORY-LIMIT] [-t|–time-limit TIME-LIMIT] [–sleep SLEEP] [-b|–bus BUS] [–queues QUEUES] [–] […]
Scheduled task runner stopped due to time limit of 60s reached
Ich verstehe denn Zusammenhang nicht. Das es genau einmal funktioniert und danach nie wieder.
Sollte es keine Lösung geben. Wie schalte ich den Admin Worker wieder ein?
Hallo Drommbart,
bei mir dasselbe Problem. Egal wie hoch ich das Memory-Limit einstelle, es läuft immer voll. Auch mit angebundenem RabbitMQ dasselbe. Bin mittlerweile etwas ratlos.
Der Admin Worker erzeugt den gleichen Fehler. Nur da bekommst du keine Fehlermeldung zu sehen (bei Cronjob-Fehler versenden die meisten Hoster eine E-Mail).
Das Problem ist ein EventDispatcher, der pro Iteration Speicher konsumiert aber nicht wieder freigibt. Habe dazu einen Forumsbeitrag die Tage geschrieben.
Hallo Max_Shop
Es scheint bei uns ein ähnliches Problem zu geben mit dem ProductExportGenerateTask. Unsere Serverlast ist nach dem Update auf 6.4.8.1 um ein vielfaches gestiegen. Vor allem mit diesem Select:
SELECT category.id as category.id, category.version_id as category.versionId, category.parent_id as category.parentId, category.parent_version_id as category.parentVersionId, category.after_category_id as category.afterCategoryId, category.after_category_version_id as category.afterCategoryVersionId, category.media_id as category.mediaId, category.display_nested_products as category.displayNestedProducts, category.auto_increment as category.autoIncrement, category.level as category.level, category.path as category.path, category.child_count as category.childCount, category.type as category.type, category.product_assignment_type as category.productAssignmentType, category.visible as category.visible, category.active as category.active, category.cms_page_id as category.cmsPageId, category.cms_page_version_id as category.cmsPageVersionId, category.product_stream_id as category.productStreamId, category.created_at as category.createdAt, category.updated_at as category.updatedAt, category.translation.name, COALESCE(category.translation.name,category.translation.name) as category.name, category.translation.breadcrumb, COALESCE(category.translation.breadcrumb,category.translation.breadcrumb) as category.breadcrumb, category.translation.slotConfig, COALESCE(category.translation.slotConfig,category.translation.slotConfig) as category.slotConfig, category.translation.linkType, COALESCE(category.translation.linkType,category.translation.linkType) as category.linkType, category.translation.internalLink, COALESCE(category.translation.internalLink,category.translation.internalLink) as category.internalLink, category.translation.externalLink, COALESCE(category.translation.externalLink,category.translation.externalLink) as category.externalLink, category.translation.linkNewTab, COALESCE(category.translation.linkNewTab,category.translation.linkNewTab) as category.linkNewTab, category.translation.description, COALESCE(category.translation.description,category.translation.description) as category.description, category.translation.metaTitle, COALESCE(category.translation.metaTitle,category.translation.metaTitle) as category.metaTitle, category.translation.metaDescription, COALESCE(category.translation.metaDescription,category.translation.metaDescription) as category.metaDescription, category.translation.keywords, COALESCE(category.translation.keywords,category.translation.keywords) as category.keywords, category.translation.customFields, COALESCE(category.translation.customFields,category.translation.customFields) as category.customFields, category.translation.createdAt, category.translation.updatedAt, category.translation.categoryId, category.translation.languageId, category.translation.categoryVersionId FROM category LEFT JOIN (SELECT category.translation.category_id, category.translation.category_version_id, [category.translation.name](http://category.translation%60.name/) as category.translation.name, category.translation.breadcrumb as category.translation.breadcrumb, category.translation.slot_config as category.translation.slotConfig, category.translation.link_type as category.translation.linkType, category.translation.internal_link as category.translation.internalLink, category.translation.external_link as category.translation.externalLink, category.translation.link_new_tab as category.translation.linkNewTab, category.translation.description as category.translation.description, category.translation.meta_title as category.translation.metaTitle, category.translation.meta_description as category.translation.metaDescription, category.translation.keywords as category.translation.keywords, category.translation.custom_fields as category.translation.customFields, category.translation.created_at as category.translation.createdAt, category.translation.updated_at as category.translation.updatedAt, category.translation.category_id as category.translation.categoryId, category.translation.language_id as category.translation.languageId, category.translation.category_version_id as category.translation.categoryVersionId FROM category_translation category.translation WHERE category.translation.language_id = ‚/_<9A>MpXT|^K‘) category.category_translation ON category.category_translation.category_id = category.id AND category.category_translation.category_version_id = category.version_id WHERE (category.version_id = ‚^O^<E3>jK¾Ku,4%‘) AND ((category.id = ‚I^G^L<M<8C>$h^Q^B‘)
Kannst du uns hier weiterhelfen?
Beste Grüsse
Pascal
Eine SQL-Abfrage sollte eigentlich kein großes Problem darstellen. Einfach mal über phpMyAdmin oder ähnlich die Query selbst testen und schauen, wie viele ms sie benötigt. Das Problem wird viel mehr die Weiterverarbeitung der Daten sein, schätze ich.
Sorry, da muss Shopware ran. Das ist ein Problem, dass tief im Core steckt.
Ich schließe mich hier mal an. Cronjobs funktionieren nicht und laufen voll.
Selbst wenn ich den Speicher auf 16GB setze… ändert nichts.
Gibt es denn schon Neuigkeiten zu diesem Thema?
Schließe mich auch an. Gibts es ein Jahr später Neuigkeiten?
Ich kann da nicht wirklich etwas neues beitragen.
Außer das der Vorgang ein absoluter Ram Fresser ist.
[product.indexer]
33871/33871 [============================] 100% 10 mins/10 mins 5.9 GiB
Also ich habe jetzt 8 GB eingestellt. Mein Hoster macht das aber auch mit. Die meisten Begrenzen das.
Auch würde ich empfehlen. Folgendes Plugin zu installieren.
Hier kann man sehen wie viel RAM freigegeben ist und noch ein paar andere Dinge.
Die php.ini ist bei mir 2mal vorhanden. Eine von beiden hat nur keine Funktion mehr. Überprüf einmal ob deine Einstellungen auch wirklich verwendet werden.
