Logo im Header vergrößern
ich bekomme es einfachnicht hin das Logo in Shopware zu vergrößern. Es bleibt immer so klein.
Hat dajemand eine Lösung wo ich das einstellen kann ?
Schau mal hier: https://shopwareianer.com/tutorials/shopware-5-logo-groesse-anpassen
Ja das kenne ich…die Datei header.lees gibt es aber schon mit folgenden Inhalt: ( wenn ich da was ändere wird das Logo aber nicht größer )
Header
Defines the styles of the Shopware storeview header and its components.
It contains the viewport specific styles inside media queries.
The header sizes are defined by the unitize mixin.
More precise designations are commented inside the document.
    // Basic header
.header-main {
    .unitize(padding-bottom, 10);
    background: #fff;
    border-bottom: 1px solid @brand-primary;
    // Hide the currency and language switcher
    .top-bar { display: none }
    // Logo
    .logo-main {
        .unitize-padding(10, 10);
        .logo–link {
            .unitize-height(35, 16);
            display: inline-block;
            max-width: 100%;
        // Smaller logo for mobile viewports
        .logo–shop {
            width: 50%;
        .logo–supportinfo { display: none; }
    .header–navigation { position: relative; }
    // Small Checkout & Registration Header
.is–ctl-checkout.is–minimal-header,
.is–ctl-register.is–minimal-header,
.is–ctl-register.is–minimal-header.is–target-checkout {
    // Header Support Info
    .header-main {
        .logo-main { width: 100%; }
        .logo–shop { width: 50% }
        .logo–link { .unitize(margin-top, 10); }
        .btn–back-top-shop {
            width: 40%;
            float: right;
            white-space: nowrap;
            overflow: hidden;
            text-overflow: ellipsis;
    // Shop navigation
.shop–navigation {
    position: relative;
    .navigation–list {
        width: 100%;
        text-align: right;
    .navigation–entry {
        .unitize(margin-right, 5);
        // General button styling in shop navigation
        .btn {
            .unitize-height(40, 16);
            .unitize-width(40, 16);
            vertical-align: middle;
        .cart–link { .unitize-padding(2, 10, 2, 6); }
        .account–link { .unitize-padding(2, 10, 2, 8); }
        .icon–basket,
        .icon–account {
            .unitize(font-size, 21);
            display: inline;
            position: relative;
            top: 0;
            left: 0;
        .icon–heart {
            .unitize(font-size, 18);
        .icon–search {
            .unitize(font-size, 22);
Das scheint mir aber sehr nach der default header.less auszuschauen.
Hast du bereits dein eigenes Theme angelegt im Theme Manager?
Dann musst du wohl das hier benutzen:
http://store.shopware.com/hosti69662086832/logo-anpassen.html
ich benutze das das Theme  Responsive was in dem Ordner schon liegt
du solltest niemals Änderungen im Bare- oder Responsive-Theme vornehmen, wenn du nicht willst, dass diese beim nächsten Update wieder verschwunden sind.
Erstell doch einfach ein eigenes Theme was vom Responsive Theme ableitet und dann erstellst du dir eine eigene LESS-Datei, wo du die CSS-Kommandos reintust (die LESS-Datei kann auch styles.less heißen): Getting started with Shopware templating .
Also mit dem Inhalt:
.header-main {
     // Logo
    .logo-main {
        .logo--link {
            .unitize-height(45, 16); // Anpassen der Höhe, Angabe in px
        .logo--shop {
@media screen and (min-width: @tabletViewportWidth) { // View für Tablets und Desktops
    .header-main {
        .logo-main {
            .logo--link {
                .unitize-height(50, 16); // 50 auf eure Höhe anpassen
            .logo--shop {
Beste Grüße
Sebastian
Das steht doch alles schon in dem Link von @kayyy
Wenn er das nicht lesen will, dann muss er eben das Plug-In kaufen. Dafür ist es ja da - für Leute wie fingerfoodmen die das nicht machen wollen. Und 25 € ist ja auch ein fairer Preis.
Erstell doch einfach ein eigenes Theme was vom Responsive Theme ableitet und dann erstellst du dir eine eigene LESS-Datei, wo du die CSS-Kommandos reintust (die LESS-Datei kann auch styles.less heißen): https://developers.shopware.com/designers-guide/getting-started/#add-less-files .
.header-main {
// Logo
.logo-main {
.logo–link {
.logo–shop {
.header-main {
.logo-main {
.logo–link {
.logo–shop {
Beste Grüße
Sebastian
DANKE jetzt ist der Taler gefallen
Hallo, hab ich jetzt soweit alles gemacht…aber die größe verändert sich nicht…das Logo bleibt so… hab es testweise auf 200 Pixel gesetzt
all.less  im Ordner ( Less )
@import “_modules/header”;
header.lees  im Ordner ( _modules )
.header-main {
// Logo
.logo-main {
.logo--link {
.logo--shop {
.header-main {
.logo-main {
.logo--link {
.logo--shop {
Deine Render-Reihenfolge scheint nicht zu stimmen.
Ich setz das Logo meist hiermit neu in einer eigenen Less-Datei im eigenen Theme.
@media screen and (min-width: 64em){
  .header-main .logo-main{
    margin-top: -40px;
  .header-main .logo-main .logo--link{
    height: 86px;
  .header-main .logo-main .logo--link img{
    height: inherit;
mmmmmmmmmm  nee wenn ich das rein schreibe geht auch nichts…
Cache gelöscht und Theme neu kompiliert hast du?
Ja…   schreibt Ihr in die Datei noch mehr ?
    margin-top: -40px;
    height: 86px;
    height: inherit;
Lach ich bin doch nicht blöd…wenn ich genau die Anleitung verfolge geht es einfach nicht…warum nicht…!!!
alles andere geht wenn ich was im template ändere aber das logo nicht…
heißt die Datei wirklich so? .less wäre richtig
Okay…nach 1 Stunde fehler gefunden… in der Doku https://shopwareianer.com/tutorials/shopware-5-logo-groesse-anpassen
Ist eine klammer zuviel oben und eine unten zuwenig.
Den sollte man eine Rechnung schicken…lach
Nein
Habe es gerade überprüft - Es ist weder eine Klammer zu viel noch zu wenig. Bei allen anderen hat es ja auch funktioniert ;)
