Layout import export
Hi there,
I have no idea how to move my layouts to another shopware 6 page . I would be glad if you could help me.
Thank you
To my knowledge, there is no import/export for that. Layouts are complex with several random UUIDs that are different in each store.
Maybe there is a plug-in in the store, but I doubt that.
I personally rebuild layouts and copy & past html. Usually does not take longer than five minutes.
Thanks for your feedback Max_Shop,
I checked the store but couldn’t find any plugin about that.
