Kategorie Update Fehler über API wenn Einkaufswelt vorhanden ist
Hallo Zusammen,
ich bekomme bei einem Test-Shop eine Fehlermeldung wenn ich über die API die Kategoriedaten ändern möchte.
Es trifft Kategorien, die eine Einkaufswelt haben.
Die Meldung:
Expected value of type "Doctrine\Common\Collections\Collection|array" for association field "Shopware\Models\Category\Category#$emotions", got "array" instead.
Das Array was ich übergebe, ist das was ich von der API gemeldet bekomme, wo ich eigentlich nur Beschreibungen, Attr, etc. abändere. Es werden keine keys hinzugefügt.
            [id] => 3
            [parentId] => 1
            [streamId] =>
            [name] => Deutsch
            [position] => 0
            [metaTitle] =>
            [metaKeywords] =>
            [metaDescription] =>
            [cmsHeadline] =>
            [cmsText] =>
            [active] => 1
            [template] =>
            [productBoxLayout] =>
            [blog] => 0
            [path] =>
            [external] =>
            [hideFilter] => 0
            [hideTop] => 0
            [changed] => 2014-11-06T19:24:16+0100
            [added] => 2014-11-06T19:24:16+0100
            [mediaId] =>
            [attribute] => Array
                    [id] => 19
                    [categoryId] => 3
                    [attribute1] =>
                    [attribute2] =>
                    [attribute3] =>
                    [attribute4] =>
                    [attribute5] =>
                    [attribute6] =>
                    [coeGoogleProductCategory] =>
                    [coeGoogleProductTyp] =>
                    [sixSeoUrl] =>
            [emotions] => Array
                    [0] => Array
                            [id] => 1
                            [parentId] =>
                            [active] => 1
                            [name] => Startseite
                            [userId] => 52
                            [position] => 1
                            [device] => 0,1,2,3,4
                            [fullscreen] => 0
                            [validFrom] => 2016-04-18T00:00:00+0200
                            [isLandingPage] => 0
                            [seoTitle] =>
                            [seoKeywords] =>
                            [seoDescription] =>
                            [validTo] =>
                            [createDate] => 2014-07-01T22:02:52+0200
                            [modified] => 2016-11-07T09:19:40+0100
                            [rows] => 23
                            [cols] => 4
                            [cellSpacing] => 10
                            [cellHeight] => 185
                            [articleHeight] => 2
                            [showListing] =>
                            [templateId] => 1
                            [mode] => resize
            [media] =>
            [customerGroups] => Array
            [0] => Array
                    [id] => 3
                    [parentId] => 1
                    [streamId] =>
                    [name] => Deutsch
                    [position] =>
                    [metaTitle] =>
                    [metaKeywords] =>
                    [cmsHeadline] =>
                    [cmsText] =>
                    [active] => 1
                    [template] =>
                    [blog] => 1
                    [path] =>
                    [external] =>
                    [hideFilter] =>
                    [hideTop] =>
                    [mediaId] =>
                            [id] => 19
                            [categoryId] => 3
                            [attribute1] =>
                            [attribute2] =>
                            [attribute3] =>
                            [attribute4] =>
                            [attribute5] =>
                            [attribute6] =>
                            [sixSeoUrl] =>
                    [emotions] => Array
                            [0] => Array
                                    [id] => 1
                                    [parentId] =>
                                    [active] => 1
                                    [userId] => 52
                                    [position] => 1
                                    [fullscreen] => 0
                                    [seoTitle] =>
                                    [seoKeywords] =>
                                    [seoDescription] =>
                                    [validTo] =>
                                    [rows] => 23
                                    [cols] => 4
                                    [cellSpacing] => 10
                                    [cellHeight] => 185
                                    [showListing] =>
                                    [templateId] => 1
                                    [mode] => resize
                    [media] =>
            [childrenCount] => 11
            [articleCount] => 4042
Hat jemand einen Tipp, womit dies zusammen hängt, bzw. wie man es beheben kann?
Beste Grüße
Steht doch in der Meldung.
Du übergibst ein Array und erwartet wird eine ArrayCollection.
Dies hier einbinden:
**use** Doctrine\Common\Collections\ArrayCollection;
und dann nutzen:
$x = new ArrayCollection($array);
Hy,
das war es leider nicht.
Ich habe nun ein zweiten Test-Shop aufgesetzt. Hier klappte es auf Anhieb richtig.
Importscript wurde nicht verändert…
