ich bin ein wenig unsicher, ob ich mit der „.htacces“-Datei bereits das Maximum raus kitzle. Vlt kann ja mal jemand drüber schauen, der Ahnung von diesem thema hat? Das wäre echt super!
RewriteEngine on
#RewriteBase /shopware/
# Https config for the backend
#RewriteCond %{HTTPS} !=on
#RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteRule backend/media/(.*) media/$1 [NC,L]
RewriteCond %{REQUEST_URI} !(\/(engine|files|templates|themes|web)\/)
RewriteCond %{REQUEST_URI} !(\/media\/(archive|banner|image|music|pdf|unknown|video)\/)
RewriteRule ^(.*)$ shopware.php [PT,L,QSA]
# Fix missing authorization-header on fast_cgi installations
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
# Block access to VCS directories
RedirectMatch 404 /\\.(svn|git|hg|bzr|cvs)(/|$)
# Restrict access to root folder files
RedirectMatch 404 /(composer\.(json|lock)|README\.md|UPGRADE\.md)$
# Staging environment
#SetEnvIf Host "staging.test.shopware.in" SHOPWARE_ENV=staging
# Development environment
#SetEnvIf Host "dev.shopware.in" SHOPWARE_ENV=dev
#SetEnv SHOPWARE_ENV dev
DirectoryIndex index.html
DirectoryIndex index.php
DirectoryIndex shopware.php
# Disables download of configuration
# Deny all requests from Apache 2.4+.
Require all denied
# Deny all requests from Apache 2.0-2.2.
Deny from all
# Enable gzip compression
AddOutputFilterByType DEFLATE text/html text/xml text/plain text/css text/javascript application/javascript application/json
ExpiresActive on
ExpiresDefault "access plus 1 month"
Header append Cache-Control "public"
Header unset ETag
FileETag None
# Match generated files like:
# 1429684458_t22_s1.css
# 1429684458_t22_s1.js
Header set Cache-Control "max-age=31536000, public"
ExpiresActive on
ExpiresDefault "access plus 1 year"
# Disables auto directory index
Options -Indexes
Options -MultiViews
# php_value memory_limit 768M
# php_value max_execution_time 120
# php_value upload_max_filesize 20M
php_flag phar.readonly off
php_flag magic_quotes_gpc off
php_flag session.auto_start off
php_flag suhosin.session.cryptua off
php_flag zend.ze1_compatibility_mode off
# AddType x-mapp-php5 .php
# AddHandler x-mapp-php5 .php
Header append X-Frame-Options SAMEORIGIN
Aber ich denke mal, da ist evtl noch Optimierungspotenzial. „gzip compression“ ist z.B. schonmal aktiv, ich dachte vlt gibt es noch ein par Kniffe in diese Richtung. Kann ja nicht schaden, wenn nochmal jemand der Ahnung hat drüber sieht.
