Invoice does not show ?
Hello together,
Invoices are not displayed. In Safari it shows: “blocked plug-in” and in Google Chrome the page is empty.
Information:
  • All plugins are deactivated
  • Version: v6.3.1.0 Stable Version
What could be the reason?
Do you know the problem or do you have ideas?
The problem is, that Safari needs a certain header to show the file directly and this header was removed due to security reasons. There are currently only two ways:
  • Save the document with Control + s
  • use another browser
Hi Moritz,
thanks for the quick feedback!
Will this be fixed in the future?
Best regards
Fil
We don’t know how to fix this without disabling a security feature. So I doubt that this will be fixed in the near future, but we will evaluate it regularily, if there is a possible solution.
A possible way to do this is to use a temporary solution:
When the document button is pressed, the document will automatically download as a PDF.
