ich bekomme leider einen Fehler bei der Installation.
Ich habe einen dedicated Server mit PHP 7.3 und MySQL 5.7.26. Das sollte über den Systemanforderungen liegen. Was kann ich machen ?
Error
Received an error message.
URL: importDatabase
Message: Internal Server Error
Response
{"valid":false,"errorMsg":"An exception occurred while executing '\n CREATE TABLE `custom_field` (\n `id` BINARY(16) NOT NULL PRIMARY KEY,\n `name` VARCHAR(255) NOT NULL,\n `type` VARCHAR(255) NOT NULL,\n `config` JSON NULL,\n `active` TINYINT(1) NOT NULL DEFAULT 1,\n `set_id` BINARY(16) NULL,\n `created_at` DATETIME(3) NOT NULL,\n `updated_at` DATETIME(3) NULL,\n CONSTRAINT `uniq.custom_field.name` UNIQUE (`name`),\n CONSTRAINT `json.custom_field.config` CHECK(JSON\_VALID(`config`)),\n CONSTRAINT `fk.custom_field.set_id` FOREIGN KEY (set\_id)\n REFERENCES `custom_field_set` (id) ON UPDATE CASCADE ON DELETE CASCADE\n ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4\_unicode\_ci;\n ':\n\nSQLSTATE[HY000]: General error: 1215 Cannot add foreign key constraint"}
