Install without samples?
Hello
Is it possible to install version 6 without sample products or orders? Locally using MAMP.
Magnus
Yes, this is the default mode without using the dummydata import feature of the Shopware 6 installer.
Thanks Jonas!
I did later realised that I was a bit inexplicit in my question (sorry). I will create my custom theme for my own store - so I cloned the Github repo with all the samples.
Coming from Magento 1 and Prestashop, Shopware is like fresh air in the morning.
/ Magnus
Instead of php psh.phar install use php psh.phar init then the demodata won’t be generated.
Great! Thanks Moritz. :slightly_smiling_face:
If you use Production Template:
bin/console system:install --basic-setup
and if i need to install via bin/setup ? is it the way how can i do with it?
