Inaccuracies in documentation
Hello. I couldn’t find the theme for my question. I’m learning SW_6 with the documentation and I’m noticing innacuracies. For example: https://docs.shopware.com/en/shopware-platform-dev-en/getting-started/indepth-guide-bundle/storefront?category=shopware-platform-dev-en/getting-started/indepth-guide-bundle   in the Step8 you wrote
 $event-\>getCriteria()-\>addAssociationPath('bundles.products.cover');
But the method addAssociationPath doesn’t exist. It is mistake, doesn’t it? Or am I wrong? It means addAssociation(‘bundles.products.cover’)
Does the forum have section for inaccuracies in documentation. That would be perfect.
Hey Aleksa,
the documentation is part of the source code https://github.com/shopware/platform/tree/master/src/Docs/Resources/current
So if you find an error, you could open an issue there, or even a pull request with a fix.
For that isse you mentioned, I will open a PR internally.
Best regards from Schöppingen
cool Michael Telgmann
