htaccess umleitung klappt nicht
Hallo
hier meine htaccess datei (shopware Vers. 5.4.5) Es geht um die Weiterleitung des Ordners: Newsletter. Wenn ich mit dieser htacces den Ordner newsletter aufrufe, erscheint trotz Umleitung die Newsletterseite. Weiß jemand wo der Fehler liegt ?
RewriteEngine on
RewriteCond %{REQUEST_URI} ^(/newsletter)$
RewriteRule ^(.*)$ / [R=301,L]
RewriteCond %{HTTPS} !=on
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
#RewriteBase /shopware/
# Https config for the backend
#RewriteCond %{HTTPS} !=on
#RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteRule backend/media/(.*) media/$1 [NC,L]
RewriteCond %{REQUEST_URI} !(\/(engine|files|templates|themes|web)\/)
RewriteCond %{REQUEST_URI} !(\/media\/(archive|banner|image|music|pdf|unknown|video)\/)
RewriteRule ^(.*)$ shopware.php [PT,L,QSA]
# Fix missing authorization-header on fast_cgi installations
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
    # Block access to VCS directories
    RedirectMatch 404 /\\.(svn|git|hg|bzr|cvs)(/|$)
# Staging environment
#SetEnvIf Host "staging.test.shopware.in" SHOPWARE_ENV=staging
# Development environment
#SetEnvIf Host "dev.shopware.in" SHOPWARE_ENV=dev
#SetEnv SHOPWARE_ENV dev
DirectoryIndex index.html
DirectoryIndex index.php
DirectoryIndex shopware.php
# Disables download of configuration
    # Deny all requests from Apache 2.4+.
          Require all denied
    # Deny all requests from Apache 2.0-2.2.
        Deny from all
# Enable gzip compression
    AddOutputFilterByType DEFLATE text/html text/xml text/plain text/css text/javascript application/javascript application/json
        ExpiresActive on
        ExpiresDefault "access plus 1 month"
        Header append Cache-Control "public"
        Header unset ETag
    FileETag None
# Match generated files like:
# 1429684458_t22_s1.css
# 1429684458_t22_s1.js
        Header set Cache-Control "max-age=31536000, public"
        ExpiresActive on
        ExpiresDefault "access plus 1 year"
# Disables auto directory index
	Options -Indexes
    Options -MultiViews
# php_value memory_limit 256M
# php_value max_execution_time 120
# php_value upload_max_filesize 20M
   php_flag phar.readonly off
   php_flag magic_quotes_gpc off
   php_flag session.auto_start off
   php_flag suhosin.session.cryptua off
   php_flag zend.ze1_compatibility_mode off
# AddType x-mapp-php5 .php
# AddHandler x-mapp-php5 .php
    Header append X-Frame-Options SAMEORIGIN
Probier mal:
RewriteRule ^newsletter / [L,R=301]
Perfekt !!
Danke !!
