htacces - Fehler erkennbar?
Hallo liebe Community,
seit dem Update auf 5.4. funktionieren meine Widgets im Backend nicht mehr. Nach Absprache mit dem Support habe ich meine htaccess in Verdacht. Evtl. wird aufgrund des Wegfalls SSL-Mischbetrieb die IP nicht korrekt weitergeleitet, etc. Das wäre meine htaccess. Entdecke jemand was auffälliges?
RewriteEngine on
#RewriteBase /shopware/
Https config for the backend
#RewriteCond %{HTTPS} !=on
#RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteRule backend/media/(.*) media/$1 [NC,L]
RewriteCond %{REQUEST_URI} !(/(engine|files|templates|themes|web)/)
RewriteCond %{REQUEST_URI} !(/media/(archive|banner|image|music|pdf|unknown|video)/)
RewriteRule ^(.*)$ shopware.php [PT,L,QSA]
Fix missing authorization-header on fast_cgi installations
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
# Block access to VCS directories
RedirectMatch 404 /\.(svn|git|hg|bzr|cvs)(/|$)
    # Restrict access to root folder files
    RedirectMatch 404 /(composer.(json|lock)|README.md|UPGRADE.md)$
Staging environment
#SetEnvIf Host “staging.test.shopware.in” SHOPWARE_ENV=staging
Development environment
#SetEnvIf Host “dev.shopware.in” SHOPWARE_ENV=dev
#SetEnv SHOPWARE_ENV dev
DirectoryIndex index.html
DirectoryIndex index.php
DirectoryIndex shopware.php
Disables download of configuration
# Deny all requests from Apache 2.4+.
Require all denied
    # Deny all requests from Apache 2.0-2.2.
Deny from all
Enable gzip compression
AddOutputFilterByType DEFLATE text/html text/xml text/plain text/css text/javascript application/javascript application/json
ExpiresActive on
ExpiresDefault “access plus 1 month”
Header append Cache-Control “public”
Header unset ETag
    FileETag None
Match generated files like:
1429684458_t22_s1.css
1429684458_t22_s1.js
Header set Cache-Control “max-age=31536000, public”
ExpiresActive on
ExpiresDefault “access plus 1 year”
Disables auto directory index
Options -Indexes
Options -MultiViews
php_value memory_limit 256M
php_value max_execution_time 120
php_value upload_max_filesize 20M
php_flag phar.readonly off
php_flag magic_quotes_gpc off
php_flag session.auto_start off
php_flag suhosin.session.cryptua off
php_flag zend.ze1_compatibility_mode off
php_value always_populate_raw_post_data -1
#   AddType x-mapp-php5 .php
#   AddHandler x-mapp-php5 .php
AddHandler php-fastcgi5.6 .php .phtml
AddHandler php-fastcgi7.0 .php .phtml
Header append X-Frame-Options SAMEORIGIN
Besten Dank für eure Hilfe.
Sijandi
Kopier dir zuerst einmal die htaccess-Datei von  Shopware 5.4 in dein Shopware Verzeichnis:
Die oben gepostete ist wahrscheinlich nicht die aktuell verwendete htaccess-Datei oder es sind vielliecht  Bestandteile beim Copy-Paste Vorgang gelöscht worden? Beim Kopieren unbedingt als Code-Schnipesl einfügen - 4. Button von rechts in der Toolbar.
Was spricht denn dafür, dass es ein htaccess-Problem ist?
Hallo hth,
besten Dank. Habe meine htaccess mit der Vorlage auf Github überschrieben, mal schauen ob es hilft.
Was dafürspricht ist eine Aussage des Supports, dass bei mir seit 5.4. nur immer die gleiche IP in den statistics geloggt wird. Und da dachte ich das es damit zusammenhängt.
Seit 5.4 habe ich nur noch ca. 3-4 Zugriffe (zumindest gemäss Shop Widgets) und dafür eine Komversionsrate von >75% :frowning:
Hast du noch eine Idee an was das liegen könnte?
Gruss
Sijandi
Du hast also keine Probleme mit der Anzeige der Statistik-Widgets im Backend, sondern mit den Daten, welche dieses anzeigt? Woher weißt Du. welche IP gelogged wird?
Welche Domain verwendest Du? Verwendest Du eigentlich  Apache als Webserver oder ngnix? Was sagen denn die Zugriffslogs von Apache und/oder Google-Analytics, sind es dort auch so wenig Zugriffe?
Hallo hth,
genau. Die Widgets sind da, aber seit 5.4 zeigen diese keine Daten mehr an, also das Besucher Online Widget. Die IP die geloggt wird sehe ich in der Datenbank. ich verwende die Domain www.drachenhort.ch und der Server ist ein Apache Server. Google Analytics zeigt brav die korrekten Zugriffe pro Tag.
Ich dachte eben es liegt aufgrund Wegfall SSL Mischbetrieb an der htaccess, aber leider hat auch deine Muster htAccess keine Abhilfe geschaffen. Kann es am Template liegen?
Grüsse
Sijandi
