htaccess + htpasswd
 Hallo!
Ich probiere seit längerem meinen Shop nur per Passwort zugägnlich zu machen. Leider wird meine htaccess inklusive htpasswd nicht akzeptiert. So sieht meine htaccess aus:
RewriteEngine on
AuthType Basic
AuthName "My Protected Area"
AuthUserFile /var/www/xy/xy/www/.htpasswd
Require valid-user
#RewriteBase /shopware/
# Https config for the backend
#RewriteCond %{HTTPS} !=on
#RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteRule backend/media/(.*) media/$1 [NC,L]
RewriteCond %{REQUEST_URI} !(\/(engine|files|templates|themes|web)\/)
RewriteCond %{REQUEST_URI} !(\/media\/(archive|banner|image|music|pdf|unknown|video)\/)
RewriteRule ^(.*)$ shopware.php [PT,L,QSA]
# Fix missing authorization-header on fast_cgi installations
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
    # Restrict access to VCS directories
    RedirectMatch 404 /\\.(svn|git|hg|bzr|cvs)(/|$)
    # Restrict access to root folder files
    RedirectMatch 404 /(autoload\.php|composer\.(json|lock|phar)|README\.md|UPGRADE-(.*)\.md|CONTRIBUTING\.md|eula.*\.txt|\.gitignore|.*\.dist|\.env.*)$
    # Restrict access to shop configs files
    RedirectMatch 404 /(web\/cache\/(config_\d+\.json|all.less))$
    # Restrict access to theme configurations
    RedirectMatch 404 /themes/(.*)(.*\.lock|package\.json|\.gitignore|Gruntfile\.js|all\.less|node_modules\/.*)$
# Staging environment
#SetEnvIf Host "staging.test.shopware.in" SHOPWARE_ENV=staging
# Development environment
#SetEnvIf Host "dev.shopware.in" SHOPWARE_ENV=dev
#SetEnv SHOPWARE_ENV dev
DirectoryIndex index.html
DirectoryIndex index.php
DirectoryIndex shopware.php
# Disables download of configuration
    # Deny all requests from Apache 2.4+.
          Require all denied
    # Deny all requests from Apache 2.0-2.2.
        Deny from all
# Enable gzip compression
    AddOutputFilterByType DEFLATE text/html text/xml text/plain text/css text/javascript application/javascript application/json application/font-woff application/font-woff2 image/svg+xml
        ExpiresActive on
        ExpiresDefault "access plus 1 month"
        Header append Cache-Control "public"
        Header unset ETag
    FileETag None
# Match generated files like:
# 1429684458_t22_s1.css
# 1429684458_t22_s1.js
        Header set Cache-Control "max-age=31536000, public"
        ExpiresActive on
        ExpiresDefault "access plus 1 year"
# Disables auto directory index
    Options -Indexes
    Options -MultiViews
# php_value memory_limit 256M
# php_value max_execution_time 120
# php_value upload_max_filesize 20M
   php_flag phar.readonly off
   php_flag magic_quotes_gpc off
   php_flag session.auto_start off
   php_flag suhosin.session.cryptua off
   php_flag zend.ze1_compatibility_mode off
   php_value always_populate_raw_post_data -1
# AddType x-mapp-php5 .php
# AddHandler x-mapp-php5 .php
    Header append X-Frame-Options SAMEORIGIN
Die htpasswd liegt somit genau neben der htaccess. Mache ich irgendeinen Fehler?
.htaccess:
# PASSWORT SCHUTZ
AuthUserFile /your/path/to/your/.htpasswd
AuthName "My-protected-Area"
AuthType Basic
require valid-user
Pack das ganz oben rein in Deine .htaccess. Das "IfModule mod_rewrite.c" und „RewriteEngine on“ lässt Du bitte weg!
Falls Du Probleme mit dem richtigen Pfad hast, benutze mal sowas hier:
Dein Pafd zu diesem Ordner: " . $dir . "";
echo "Dein Pfad zu Deiner.htpasswd: " . $dir . "/.htpasswd" . "";
Diesen PHP Code einfach in eine Texteditor kopieren und die Datei z.B. als pfad.php speichern. Dann schmeisst Du diese Datei in den Ordner, wo Deine zwei Dateien (.htaccess & .htpasswd) drin sind.
Dann einfach im Browser aufrufen:
www.deinedomain.de/pfad.php
Bei mir funktioniert das auch mit der RewriteEngine.
Aber vielen Dank für den Tip mit dem PHP Code! Ich hab schon erfolglos versucht, irgendwie in den Templates PHP zu schreiben.
