How to turn on 'guest checkout'
I must be overlooking an option to turn guest checkout on for one of the saleschannels I run within our Shopware environment, but I really can’t find is. Who can help me out? Thanks!
Hi Duff,
guest checkout is always on. You should find a checkbox labelled „Do not create a customer account.“ below the first name field (with the default theme).
Thanks! So there is no way to turn it off other than removing it form the template?
Hello Duff,
you are correct, there are no settings in the admin area to just switch it off.
I do not think as well that there is a setting in the admin area.
