How to prevent order confirmation mail
Hello,
Anybody have an idea to prevent order confirmation mail.Because i have created one sample payment method. But mail goes before it comes to my payment file.So I need to prevent before it triggers.
Best Regards
Charles
Hi charles I got the same Issue.
As far as i know this depends on the Payment Gateway you use. If you use a Async Payment Gateway there is no way around this…
Only with SynchronousPayment Gateway this can be solved.
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski „Moritz Naczenski“)‍ is my guess is correct? Would be glad to have confirmation.
Any updates one this ? I’ve got the same issue
Maybe check the settings of the email? You could also try to ask the service support.
