How to prevent EntityWrittenEvent from triggering again and again?
If you want to subscribe an EntityWrittenEvent and update the same entity. the event sucriber will work as a loop.
In order to prevent this, you can use the Shopware\Core\Framework\DataAbstractionLayer\VersionManager
class
for eg:
public function update(array $data, Context $context)
        $affected = $this->versionManager->update($this->productDefinition , $data, WriteContext::createFromContext($context));
    public function upsert(array $data, Context $context)
        $affected = $this->versionManager->upsert($this->productDefinition , $data, WriteContext::createFromContext($context));
    public function create(array $data, Context $context)
        $affected = $this->versionManager->insert($this->productDefinition, $data, WriteContext::createFromContext($context));
