Hi there,
I’m trying to override the label or description of an order line item, after a customer placed an order. To do so, I tried to listen to the order.written-event. The event handling looks like this (simplified):
// This is the event-handler
public function onOrderWritten(EntityWrittenEvent $event)
foreach ($event->getWriteResults() as $result) {
$orderId = $result->getPrimaryKey();
$criteria = new Criteria();
$criteria->addFilter(new EqualsFilter('orderId', $orderId));
$data = $this->orderLineItemRepository->search($criteria, $context);
$updates = [];
foreach ($data->getEntities() as $lineItem) {
$updates[] = [
'id' => $lineItem->getId(),
'label' => $lineItem->getLabel() . ' <some more info>',
if (!empty($updates)) {
$this->orderLineItemRepository->update($updates, $context);
This runs into an endless loop, I think, this might be, because the order.written-event is called everytime, I update the line item. So it triggers a recursion… Is there another way on how to override the line items?
And, for general understanding: Is there anything like an EntityManager, like the one from Symfony/Doctrine? Or do I always have to look for the correct keys in the entity-table inside the db, to update values on an entity?
Thanks in advance
