How to get error details on response 500 api/_info/entity-schema.json?
After I activated a new plugin, I get a blank white screen after admin login. The storefront still works, no errors in the error logs. No profiler in admin, so no XDebug?
In my browser’s developer tools network tab, I see that the request to api/_info/entity-schema.json responds with a 500 Internal Server error.
But I don’t find any details about the error. No logs, no response payload, although it’s a DEV environment (Dockware).
I already checked the migration class, the entity definition, and the SQL table in adminer, where I suspect to find a subtle mismatch somewhere.
Is there any way to get more details about the error beyond the terse HTTP status message?
I had the same problem. I believe it was some difficulty interpreting the route to this JSON file, since I was running the project with the internal PHP server (php -S …). After using the valet that I have installed on my machine and creating a local domain for the project (shopware.test), I no longer had problems with this white screen when accessing the admin.
Another case where this error happens, when you are using elasticsearch but no elasticsearch (or opensearch) node is running.
I know it’s an old thread, but it’s the first google result popping up related to this error.
