I want to override sSaveComment function in Shopware engine/Shopware/Core/sArticles.php
since i want to replace at the place of (1 to 10 ) to (1 star , 2stars ,3stars) etc .
Check the file /themes/Frontend/Bare/frontend/detail/comment/form.tpl
You’ll find the following:
{* Review Rating *}
{block name='frontend_detail_comment_input_rating'}
{s name="Rate10"}{/s}
{s name="Rate9"}{/s}
{s name="Rate8"}{/s}
{s name="Rate7"}{/s}
{s name="Rate6"}{/s}
{s name="Rate5"}{/s}
{s name="Rate4"}{/s}
{s name="Rate3"}{/s}
{s name="Rate2"}{/s}
{s name="Rate1"}{/s}
{/block}
If you want to change your rating system from 1 - 10 to 1 - 5 you’ll have to do something like the following:
Note: Please don’t change the file in the Bare Template, create an own Template / Theme and edit this block in your own Theme. Check documentation.
{extends file="parent:frontend/detail/comment/form.tpl"}
{namespace name="frontend/detail/comment"}
{* Review Rating *}
{/block}
If you just want to change the text which is shown in the dropdown, you can just edit the snippets via your shopware backen (Snippets: Rate1 - Rate10) and don’t need to change anything in the template / theme itself.
Super logic .
Thanks so much
You’re welcome
Thanks for your helpful explanation
