how can i extend engine/shopware/core/sExport.php in my plugin?
I have an additional field attr21 in table s_articles_attributes.
In order to export it, i need to add this field to sCreateSql() function inside engine/shopware/core/sExport.php as follows
              $sql=" …
                d.weight,
                d.position,
                at.attr1, at.attr2, at.attr3, at.attr4, at.attr5, at.attr6, at.attr7, at.attr8, at.attr9, at.attr10,
                at.attr11, at.attr12, at.attr13, at.attr14, at.attr15, at.attr16, at.attr17, at.attr18, at.attr19, at.attr20, at.attr21,
                s.name as supplier,
                u.unit
But the problem is i cant add it directly over here, so I need to extend sExport.php class and add attr21 through my plugin?
how can i extend sExport.php?
Inside Install use after hook.
Than something like
public function afterCoreExportCreateSql(Enlight_Hook_HookArgs $args){
$sql = $args->getReturn();
//modify $sql
$args->setReturn($sql);
Thanks alot Steinsoftware,
just one more thing that against which event should i register afterCoreExportCreateSql that is:
private function registerEvents()
        $this->subscribeEvent(
            ’ afterCoreExportCreateSql ’
use an after hook
‚sExport::sCreateSql::after‘
wow great! thanks a ton Thumb-Up
