Hello,
I’m trying to lookup properties by their id using the DAL, but I cant seem to find anything on it.
Thanks in advance ![]()
Hello,
Did you use the Criteria filter? Reading data - Shopware Developer
Thanks for the quick reply, I considered using them, but I’m not quite sure on what, is there something like a propertyRepository or something like that?
Sure, every entity has its own repository: Reading data - Shopware Developer
