Hi Guys,
I have a situation,
On feed generation, I need to find the category custom field of parent product.
So I tried something like this
{% if product.parent %}
{% set parentCategories = product.parent.categories %}
{% else %}
{% set productCategories = product.categories %}
{% endif %}
{% for category in productCategories %}
{{ category.customFields.xxxxxx }}
{% endfor %}
And I got this error message
It is not possible to read the parent association directly. Please read the parents via a separate call over the repository
I believe this is not possible in Shopware directly and we needed an extra query.
So how can we handle this?
I thought about update product Export criteria using some event, create a twig filter, update database directly. What may be the best solution?
Or is there any direct solutions available?
Please share your opinions.
Thank you
