Fehlermeldung Warenkorb
Was sagt der Fehler aus? Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Class Shopware\CustomModels\Customizing\Group does not exist in Doctrine/Common/Persistence/Mapping/RuntimeReflectionService.php on line 73 Stack trace: #0 Doctrine/Common/Persistence/Mapping/RuntimeReflectionService.php(73): ReflectionClass->__construct(‚Shopware\Custom…‘) #1 Doctrine/ORM/Mapping/ClassMetadataInfo.php(746): Doctrine\Common\Persistence\Mapping\RuntimeReflectionService->getClass(‚Shopware\Custom…‘) #2 Doctrine/ORM/Mapping/ClassMetadataFactory.php(579): Doctrine\ORM\Mapping\ClassMetadataInfo->wakeupReflection(Object(Doctrine\Common\Persistence\Mapping\RuntimeReflectionService)) #3 Doctrine/ORM/Mapping/ClassMetadataFactory.php(175): Doctrine\ORM\Mapping\ClassMetadataFactory->wakeupReflection(Object(Doctrine\ORM\Mapping\ClassMetadata), Object(Doctrine\Common\Persistence\Mapping\RuntimeReflectionService)) #4 Doctrine/ORM/EntityManager.php(269): Doctrine\ORM\Mapping\ClassMetadataFactory->getMetadataFor(‚Shopware\Custom…‘) #5 Shopware/Components/Model/ModelManager.php(145): Doctrine\ORM\EntityManager->getClassMetadata(‚Shopware\Custom…‘) #6 Shopware/Plugins/Community/Frontend/SwagCustomizing/Bootstrap.php(492): Shopware\Components\Model\ModelManager->getRepository(‚Shopware\Custom…‘) #7 Shopware/Plugins/Community/Frontend/SwagCustomizing/Bootstrap.php(1155): Shopware_Plugins_Frontend_SwagCustomizing_Bootstrap->getGroupRepository() #8 Shopware/Plugins/Community/Frontend/SwagCustomizing/Bootstrap.php(783): Shopware_Plugins_Frontend_SwagCustomizing_Bootstrap->fixValues(Array) #9 Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Frontend_SwagCustomizing_Bootstrap->onUpdateBasketArticle(Object(Enlight_Hook_HookArgs)) #10 Enlight/Event/EventManager.php(248): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Hook_HookArgs)) #11 Enlight/Hook/HookManager.php(183): Enlight_Event_EventManager->filter(‚sBasket::sUpdat…‘, NULL, Object(Enlight_Hook_HookArgs)) #12 cache/proxies/sBasketProxy.php(23): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_sBasketProxy), ‚sUpdateArticle‘, Array) #13 engine/core/class/sBasket.php(960): Shopware_Proxies_sBasketProxy->sUpdateArticle(‚683‘, ‚1‘) #14 Shopware/Controllers/Frontend/Checkout.php(659): sBasket->sGetBasket() #15 Shopware/Controllers/Frontend/Checkout.php(114): Shopware_Controllers_Frontend_Checkout->getBasket() #16 Enlight/Controller/Action.php(148): Shopware_Controllers_Frontend_Checkout->cartAction() #17 Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‚cartAction‘) #18 Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #19 Shopware/Components/HttpCache/HttpKernel.php(79): Enlight_Controller_Front->dispatch() #20 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #21 Shopware/Components/HttpCache/AppCache.php(242): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #22 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(403): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #23 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(303): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #24 Shopware/Components/HttpCache/AppCache.php(162): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #25 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #26 Shopware/Components/HttpCache/AppCache.php(97): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #27 Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #28 Enlight/Application.php(192): Shopware_Bootstrap->run() #29 shopware.php(83): Enlight_Application->run() #30 {main}
erledigt.
wie hast du es gelöst, ich habe die selbe Fehlermeldung! wenn ich das modul deinstallieren/installieren lasse ist es weg aber sobald ich den Shopcache leere tritt die Fehlermeldung wieder auf :shock:
