Fehlermeldung "The provided X-CSRF-Token for path..." und kein Mailversand seit Tagen
es werden seit zwei Tagen keine Mails mehr versendet. Alles was ich finde, sind diese Fehlermeldungen, die ich leider nicht verstehe. Kann jemand weiterhelfen?
***Cirtical
The provided X-CSRF-Token for path „/checkout/deleteArticle/sDelete/499102/sTargetAction/cart“ is invalid. Please go back, reload the page and try again.
*** Error
Shopware\Components\CSRFTokenValidationException: The provided X-CSRF-Token for path „/checkout/deleteArticle/sDelete/499102/sTargetAction/cart“ is invalid. Please go back, reload the page and try again. in /engine/Shopware/Components/CSRFTokenValidator.php:144 Stack trace:
#0 /engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator->checkFrontendTokenValidation(Object(Enlight_Controller_ActionEventArgs))
#1 /engine/Library/Enlight/Event/EventManager.php(219): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#2 /engine/Library/Enlight/Controller/Action.php(175): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#3 /engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight_Controller_Action->dispatch(‚deleteArticleAc…‘)
#4 /engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 /engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#6 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#8 /engine/Shopware/Components/HttpCache/AppCache.php(260): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#9 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(420): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /engine/Shopware/Components/HttpCache/AppCache.php(187): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#14 /var/www/clients/client783/web9204/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#15
Shopware 5.5.8
Gruß Lisa
