Hallo Community,
ich habe versucht einen Cronjob auf meinem Server bei AIXPRO einzurichten, der stündlich eine URL abrufen soll und bekomme folgende Fehlermeldung:
Url ‘http://gayoktees.de/backend/spreadshirt/updatePriceAndStock’ fetched
Status: 503
Output:
The provided CSRF-Token is invalid. If you’re sure that the request should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in engine/Shopware/Components/CSRFTokenValidator.php on line 108
Stack trace:
#0 [internal function]: Shopware\Components\CSRFTokenValidator-\>checkBackendTokenValidation(Object(Enlight\_Controller\_ActionEventArgs))
#1 engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
#2 engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
#3 engine/Library/Enlight/Controller/Action.php(143): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
#4 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('updatePriceAndS...')
#5 engine/Library/Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
#6 engine/Shopware/Kernel.php(176): Enlight\_Controller\_Front-\>dispatch()
#7 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#8 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#9 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
#10 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
#11 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
#12 {main}
Hat das evtl mit dem CRON Plugin zu tun? Ich habe es nur aktiviert, aber ansonsten nichts eingetragen.
Freue mich wie immer über jede Antwort.
