Fehler nach Update aus EA2
Hallo zuammen,
nach dem Update kein Backend & Frontend verfügbar:
PayPal wurde zwar installiert jedoch noch nicht konfiguriert, evenutell mal den Shop Cache via SSH löschen?
2019/10/15 14:46:54 [error] 1028#1028: *13132 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: The service "Swag\PayPal\PayPal\Resource\TokenResource" has a dependency on a non-existent service "shopware.cache". in /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php:86
Stack trace:
#0 /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(82): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Object(Symfony\Component\DependencyInjection\Reference), false)
#1 /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(49): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->processValue(Array, false)
#2 /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(91): Symfo" while reading response header from upstream, client: IP*. ***.**. **, server: sw61.******.timmeserver.de, request: "GET /api/v1/_action/update/finish/a74842a3a1134d819cfc4b2311e9aa50 HTTP/1.1", upstream: "fastcgi://unix:/var/lib/php5-fpm/web7.sock:", host: "sw61. ******.timmeserver.de", referrer: "http://sw61.******.timmeserver.de/recovery/update/index.php/done"
2019/10/15 14:47:04 [error] 1027#1027: *13137 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: The service "Swag\PayPal\PayPal\Resource\TokenResource" has a dependency on a non-existent service "shopware.cache". in /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php:86
Stack trace:
2019/10/15 14:47:09 [error] 1028#1028: *13140 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: The service "Swag\PayPal\PayPal\Resource\TokenResource" has a dependency on a non-existent service "shopware.cache". in /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php:86
Stack trace:
#2 /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(91): Symfo" while reading response header from upstream, client: IP*. ***.**. **, server: sw61.******.timmeserver.de, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/lib/php5-fpm/web7.sock:", host: "sw61. ******.timmeserver.de"
2019/10/15 14:47:16 [error] 1028#1028: *13145 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: The service "Swag\PayPal\PayPal\Resource\TokenResource" has a dependency on a non-existent service "shopware.cache". in /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php:86
Stack trace:
#2 /var/www/clients/client1/web7/web/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(91): Symfo" while reading response header from upstream, client: IP*. ***.**. **, server: sw61.******.timmeserver.de, request: "GET /admin HTTP/1.1", upstream: "fastcgi://unix:/var/lib/php5-fpm/web7.sock:", host: "sw61. ******.timmeserver.de"
Gruß
Dennis
Das ist natürlich auch ein Weg EA2 zu anouncen :smiley:
Habe ebenfalls einen Fehler:  The service “Swag\PayPal\PayPal\Resource\TokenResource” has a dependency on a non-existent service “shopware.cache”.
=D war ich schneller als Shopware?
Hallo Dennis,
bitte beachte die Hinweise auf der Changelog Seite: Shopware Changelog | Shopware Insbesondere diese Schritte:
  • Deaktivieren Sie alle Plugins
  • Führen Sie das Shopware Update durch
  • Aktualisieren und aktivieren Sie alle Plugins, die mit der neuen Version kompatibel sind.
Dann sollte das Update auch funktionieren
Viele Grüße aus Schöppingen
cool Michael Telgmann
13:00 Uhr auf der Website, aber keine Email oder Sterbenswort darüber :smiley:
Hallo Michael,
danke, da war ich wohl zu schnell, da ich eigentlich keine nenneswerten Plugins hatte hab ich das übersehen.
Nuja gibt es halt eine neue Testumgebung :slight_smile:
Diesen Changelog habe ich aus lauter Begeisterung ebenfalls übersehen. Hier die Lösung:
  • In der Datenbank-Tabelle: „plugin“ -> „SwagPayPal“ den Wert „active“ statt 1 auf 0 setzen.
  • Cache leeren in Console: bin/console cache:clear
  • fertig
Sorry, aber was ist das?
Wieviel Div-Container muss man eigentlich für ein Filter-Selectbox einsetzen?
Normale Frontendentwickler: 0
Shopware:
                                                            Farbe
        grün
brettvormkopp ich sehe da Bootstrap Klassen, das ist doch was schönes :wink:
Aber smart ist das wirklich nicht…
